Originally posted by snake TSo in that light, what would be the difference between TAv and P (the latter where one can select auto ISO and still control aperture and shutter)?
The difference between TAV and Hyper-Program + auto-ISO is like the difference between full manual and Av or Tv except that ISO is on auto.
You use TAv when you need to control both aperture and shutter speed, Hyper-P can be used when it is enough to control one of them. The great thing about Hyper-P is that it is a very flexible mode that quickly can switch between Av and Tv modes. Adjust Aperture and camera goes into Hyp-Av and adjust shutter speed and camera go into Hyp-Tv. Press green button to go back into Hyp-P.
- In TAv you manually set aperture and shutter speed and camera adjust ISO. Exposure compensation adjust ISO.
- In Hyp-Av + auto-ISO you manually set aperture and the camera set shutter speed and ISO, and exposure comp. adjust shutter speed.
- In Hyp-Tv + auto-ISO you manually set shutter speed and the camera set aperture and ISO, and exposure comp. adjust aperture.
