09-10-2012, 06:33 PM   #1
Can the anti aliasing filter be removed from the K5
09-10-2012, 06:39 PM - 1 Like   #2
Yes, by trading it up to a mark II
There's a thread on the topic here, with a link to another thread with even more discussion: https://www.pentaxforums.com/forums/pentax-dslr-discussion/82627-anybody-had-...r-removed.html
09-10-2012, 07:02 PM   #3
What is an anti aliasing filter? Someone please help!
What does it do?
09-11-2012, 06:12 AM   #4
titrisol's Avatar
Location: In the most populated state... state of denial
It helps prevent Moire effects between pixels, but it somehow softens the images at high reoslution
Anti-aliasing filter - Wikipedia, the free encyclopedia
09-11-2012, 06:13 AM   #5
Mike V's Avatar
QuoteOriginally posted by alamo5000 Quote
What does it do?
In layman's terms, it is the filter that processes the incoming digital signal so that you do not get moire in your images, Why would you want moire? You wouldn't, ever, so why would you want to remove the filter that keeps it from happening? Dunno.
09-11-2012, 06:14 AM   #6
Mike V's Avatar
QuoteOriginally posted by Mike V Quote
A quick read of this article will lay it all out for you:Nikon D800 vs. D800E
09-11-2012, 06:19 AM   #7
Clavius's Avatar
You would want to remove that filter because it will give you a higer resolution / higher IQ image. The low pass filter blurs the total image, not only the parts with the moire.
Moire only happens under certain conditions and is VERY easily fixed locally in PP. I can even imagine eventually inbody software will and remove any moire before writing the file to the SD card.
I doubt that Pentax will suport the removal of the low pass filter though. Then the only advantage of the K-5IIs, and the reason for its pricing, will be gone.
09-11-2012, 09:22 AM   #8
I believe that IR conversions remove the AA (Low Pass) filter and replace it with the IR filter. I have a K20 with the IR conversion and notice no moire artifacts.
09-11-2012, 09:35 AM   #9
Clavius's Avatar
Please see the following post and link in this thread: https://www.pentaxforums.com/forums/pentax-k-5/174809-removing-aa-filter-k5.html
It appears that it has been tried without luck!
QuoteOriginally posted by Couscousdelight Quote
Don't do It !
Klaus from photozone do the same operation, it results a unusable K5 !
Photozone - Pentax K5 tests -
"...The K5 seems to be very unique regarding its AA filter characteristic.
After the AA removal the camera produced "shadowed" images for wide-angle settings.
The service company didn't have an explanation but that was the first time the experienced this problem.
I will get a brand new K5 as a replacement, BTW, so the procedure had no impact on my wallet...."
Hopefully, the new K-5IIs will reveal if there is a way to remove the AA filter from the discontinued K5.
09-11-2012, 09:27 PM   #10
tabl10s's Avatar
The link said Moire can't be fixed in PP, Have you done it before?
09-11-2012, 10:23 PM - 1 Like   #11
Clavius's Avatar
All the time with my IR camera. All that a low pass filter does is blur the image. And as we all know, that can be done locally in PP too.
camera, dslr, filter, k-5, k-5 ii, k-5 iis, k5, pentax k-5
F50/1.4 with filter threads removed? Docrwm Pentax SLR Lens Discussion 9 08-16-2012 08:16 PM
anti-Aliasing filter for 7D Anvh Canon, Nikon, Sony, and Other Camera Brands 3 06-30-2012 10:17 AM
Anybody had their AA filter removed? Frank Fletcher Pentax DSLR Discussion 3 12-08-2009 12:17 PM
Pentax please REMOVE Anti-Aliasing on K-7 LCD illdefined Pentax DSLR Discussion 22 09-20-2009 02:44 PM
Aliasing on Resize wa5am Digital Processing, Software, and Printing 2 11-17-2008 08:20 AM
All times are GMT -7. The time now is 04:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
