Originally posted by glennbp Well, as it turns out the GPS metadata was present on all the images. The reason Lightroom was not recording it is because I was using a metadata preset that simply overwrote the GPS coordinates. The choice then is use the preset and then add the GPS data manually or don't use a preset and add other IPTC data manually. It seems you can't have both which strikes me as a bit weird.
What metadata preset? Seems like you should be able to only include the metadata you are actually setting in the preset, and the rest should be unaffected. After all, your lens data, etc is preserved, right? But I'm curious what you would be presetting in the metadata -- I have some copyright stuff in there, but it has no effect on GPS or anything else...
