Loyal Site Supporter Join Date: Mar 2007 Location: West GTA, Ontario, Canada | Playing with the K 5 IIs
Well, I broke down and bought the K5IIs. Have had a K20 for a few years and until recently didn't quite see that value in upgrading. The K20 was a wonderful upgrade from my *ist D. More recently, especially when out with those persons shooting their newer canons at the nikonians, noticed the images from the K20 seemed a little less vibrant compared to the others...too much PhotoShop required!
Debated the II versus the IIs and decided on the IIs.
Lots of apprehension as you can imagine and not to downplay the value of the discussion in the forums, actually working with it on your own terms is the true test for me. Well today with a few minutes between work activities to play, tried to dispel some of the worst things I had heard about the new series -- focus sharpness, graininess at high ISO and alienation of non Pentax lenses. Snapped on the Sigma 150-500 zoomed it to 500 and shot this tree about 35' out. The ISO was set to 51200 and the focus to automatic with the "Program" setting. Attached is the result. The image was shot in Adobe RAW, converted to a .jpeg in Photoshop and resized to email...no other enhancements.\
Here's the EXiF data courtesy of PhotoME
PhotoME version: 0.8ß2 (Build 891)
[Overview]
File name: C:\Users\Owner\Documents\_ART0036.DNG
File type: Adobe Digital Negative RAW
File size: 33,511.5KB
Creation date: 11/12/2012 07:57
Last modification: 11/12/2012 18:44
Make: PENTAX
Camera: PENTAX K-5 II s
Lens: Unknown (Lens Id: 8 15)
Software: K-5 II s Ver 1.00
Dimension: 4992 x 3284px(16.4 MP, 3:2)
Focal length: 500mm(equiv. 750mm)
Aperture: F9.5
Exposure time: 1/1500"
ISO speed rating: 51200/48°
Program: Program AE
Metering Mode: Pattern
White Balance: Auto
Focus Mode: AF-S
Image Stabilizer: stabilized
Noise Reduction: Off
Flash: Flash did not fire, compulsory flash mode
[Image]
New subfile type: Reduced-resolution image data
Image width: 160px
Image height: 120px
Number of bits per component: 8, 8, 8
Compression scheme: uncompressed
Pixel scheme: RGB
Manufacturer: PENTAX
Image input equipment model: PENTAX K-5 II s
Image data location: 0x00019800
Orientation of image: 0° (top/left)
Number of components: 3
Number of rows per strip: 120rows
Bytes per compressed strip: 57600bytes
Image resolution in width direction: 300dpi
Image resolution in height direction: 300dpi
Image data arrangement: Chunky Format (Interleaved)
Unit of X and Y resolution: inch
File change date and time: 2012-11-12 07:57:44
SubIFD Pointer: 0x000193CE, 0x00019548
Exif IFD Pointer: 0x020B9CA4
GPS IFD Pointer: 0x000197E0
DNG Version: 1.1.0.0
DNG Backward Version: 1.1.0.0
Unique Camera Model: PENTAX K-5 II s
Color Matrix 1: [0.9907,-0.4907,-0.0813], [-0.3496,0.9834,0.4287], [-0.0183,0.0383,0.7006]
Color Matrix 2: [0.8537,-0.2580,-0.1143], [-0.3995,1.2301,0.1881], [-0.1007,0.1765,0.6712]
Analog Balance: 1, 1, 1
As Shot Neutral: 0.4876190476, 1, 0.5481798715
Baseline Exposure: -0.546859741
Baseline Noise: 1
Baseline Sharpness: 1
Linear Response Limit: 1
DNG Private Data: 0x00000382
Calibration Illuminant 1: 17
Calibration Illuminant 2: 21
[Additional Image Data (1)]
New subfile type: Not set
Image width: 4992px
Image height: 3284px
Number of bits per component: 16
Pixel scheme: CFA (Color Filter Matrix)
Image data location: 0x00027900
Number of components: 1
Number of rows per strip: 3284rows
Bytes per compressed strip: 32787456bytes
CFA Repeat Pattern Dimension: Horizontal repeat pixel unit: 2, Vertical repeat pixel unit: 2
CFA Pattern 2: [Blue, Green], [Green, Red]
CFA Layout: Rectangular (or square) layout
Black Level Repeat Dim: Rows: 2
Cols: 2
Black Level: 0, 0, 0, 0
White Level: 15862
Default Scale: Horizontal: 1
Vertical: 1
Default Crop Origin: Horizontal: 22
Vertical: 10
Default Crop Size: Horizontal: 4928
Vertical: 3264
Bayer Green Split: 2000
Relative strength of the camera's anti-alias filter: 0
[Additional Image Data (2)]
Image width: 4928px
Image height: 3264px
Compression scheme: JPEG
Pixel scheme: YCbCr
Image data location: 0x01F6C500
Number of rows per strip: 3264rows
Bytes per compressed strip: 1362159bytes
White point chromaticity: 0.313, 0.329
Chromaticities of primaries: [0.64,0.33,0.21], [0.71,0.15,0.06]
Color space transformation matrix coefficients: 0.299, 0.587, 0.114
Subsampling ratio of YtoC: YCbCr4:2:2
Y and C positioning: Co-Sited
[Camera]
F number: F9.5
Exposure program: Normal program
Exif version: 2.21
Date and time of original data generation: 2012-11-12 07:57:44
Date and time of digital data generation: 2012-11-12 07:57:44
Shutter speed: 10.55Tv (1/1500")
Aperture: 6.5Av (F9.5)
Exposure bias: ±0EV
Metering mode: Pattern
Lens focal length: 500mm
Sensing method: One-chip color area sensor
Custom image processing: Normal process
Exposure mode: Auto exposure
White balance: Auto
Focal length in 35 mm film: 750mm
Scene capture type: Standard
Contrast: Normal
Saturation: Normal
Sharpness: Normal
Subject distance range: Distant view
[Manufacturer notes]
Pentax Version: 10.0.0
Pentax Model Group: Group 1 (DSLR series & Various Optio models)
Preview Image Size: 640 x 480
Preview Image Length: 36890bytes
Preview Image Start: 0x000087DE
Pentax Model: 0x12f71
Date: 2012-11-12
Time: 07:57:44
Quality: RAW
Flash Mode: Off, Did not fire; Internal
Focus Mode: AF-S
??? (000E): 65535, 0
Exposure Time: 1/1515.2"
F Number: F9.5
ISO: 51200/48°
??? (0016): 50
Metering Mode: Multi-segment
Auto Bracketing: 0 EV, No Extended Bracket
White Balance: Auto
Focal Length: 500mm
Saturation: Normal
Contrast: Normal
Sharpness: Normal
DSP Firmware Version: 1.00.00.00
CPU Firmware Version: 1.00.00.00
Effective LV: 8LV
Picture Mode: Program AE (Hyper-Program); 1/2EV steps
Drive Mode: Single-frame; No Timer; Shutter Button; Single Exposure
??? (0035): 12061, 7988
Color Space: Adobe RGB
Image Area Offset: x = 22px, y = 10px
RAW Image Size: width = 4928px, height = 3264px
??? (003D): 8192
Preview Image Borders: top = 28, bottom = 28, left = 0, right = 0
Lens ID: 8+15+0+0
Pentax Lens Type: DA or DA*
Lens Name(s) of the ID: Unknown (Lens Id: 8 15)
Camera Temperature: 21°C
AE Lock: On
Flash Exposure Compensation: ±0
Image Tone: Portrait
Color Temperature: Not set
SR Result: stabilized
Shake Reduction (Setup): 151
Shutter Release Half Press Time: 4.25sec
SR Focal length: 356mm
Shutter Count: 36
??? (0060): 0, 0, 0, 0
??? (0062): 8
??? (0067): 1
??? (0068): 1, 0
Dynamic Range Expansion: Off
??? (006B): 0, 0, 11, 12
??? (006C): 0, 0
??? (006D): 0, 0
??? (006E): 0, 0
??? (006F): 0
??? (0070): 0, 0
??? (0071): 255, 4
AF Adjustment: ±0
??? (0073): 65535
??? (0074): 65535
??? (0076): 0, 0
??? (0077): 0, 0
??? (0078): 0, 0
??? (0079): 0, 0
??? (007A): 2, 0
??? (007D): 0, 0, 0
??? (007E): 15862
??? (007F): 65535
Black Point: [0, 0, 0, 0]
White Point: [16800, 8192, 8192, 14944]
Picture Mode 2: Program AE
Program Line: Normal
EV Steps: 1/2 EV steps
E-Dial In Program: Tv or Av
Aperture Ring Use: Permitted
Flash Options: Red-eye reduction
Metering Mode (2): Multi-segment
AF Point Mode: Auto
Focus Mode 2: AF-S
AF Point Selected 2: 0
Drive Mode 2: Single-frame
Exposure Bracket Step Size: 0.3
Bracket Shot Number: n/a
White Balance Set: Auto
Multiple Exposure Set: Off
??? (0205): 0
??? (0205): 0
??? (0205): 124
Manufacture Date?: 2012-10-13
Camera has been serviced?: Serviced bit not set (Value: 2?)
Production ID?: 2
Internal Serial Number?: 7047694
Number of Matrices: 18matrices
Matrix 1: [12512,-4352,32], [-1728,12832,-2912], [288,-3392,11296]
Matrix 2: [14015,-4582,-1241], [-2027,15021,-4802], [-141,-4627,12960]
Matrix 3: [14333,-4934,-1207], [-2592,15598,-4814], [-508,-3831,12531]
Matrix 4: [14397,-5065,-1140], [-2464,15713,-5057], [-845,-5311,14348]
Matrix 5: [16225,-6840,-1193], [-2446,17469,-6831], [-380,-2963,11535]
Matrix 6: [8831,-611,-28], [-1221,11035,-1622], [-146,-283,8621]
Matrix 7: [12940,-5515,767], [-1361,13305,-3752], [294,-4961,12859]
Matrix 8: [6766,2689,-1263], [-515,9159,-452], [1758,384,6050]
Matrix 9: [12512,-4352,32], [-1728,12832,-2912], [288,-3392,11296]
Matrix 10: [2783,5826,-417], [2784,5825,-417], [2784,5826,-418]
Matrix 11: [757,8809,-1374], [758,8808,-1374], [758,8809,-1375]
Matrix 12: [3380,5590,-778], [3380,5590,-778], [3380,5590,-778]
Matrix 13: [8450,-205,-53], [8450,-205,-53], [8450,-205,-53]
Matrix 14: [10174,-2662,680], [10174,-2662,680], [10174,-2662,680]
Matrix 15: [6946,-275,1521], [6946,-275,1521], [6946,-275,1521]
??? (0222): 8323
??? (0222): 8036
??? (0222): 8061
??? (0222): 8348
??? (0222): 8520
??? (0222): 8438
??? (0222): 7987
??? (0222): 7946
WB BA compensation: ±0
WB GM compensation: ±0
??? (0229): 4519585
??? (0231): 0, 0, 0, 0
D-Range Compensation: 4
??? (03FF): 1, 24754, 1, 0, 1, 218, 218, 0, 250, 21, 21, 514, 514, 518, 518
I was reasonably pleased with the results...far better than expected and a far cry from anything the K20 could have produced.
Comparing the cameras, I immediately liked the feel of the K5IIs. I was initially worried the reported "smaller size" may have not worked with my "mitts". The shutter "noise" is different in a pleasant way. The focus is so quick, with a silent focusing lens it is there before the K20 could have thought about it. A couple of times had to double check to see if it had focused as it seemed too quick to be right! Charging the battery for the first time was a bit unnerving...it was about five hours. It some of the literature it states a charge time of about 300 plus minute. With the optional battery grip, that's a day's worth of charging. Hopefully the recharge will be proportional to depletion. I like the fact the optional battery grip has the alternate holder for AA batteries. Probably will never need it but it's nice insurance when away from home for an extended day's shooting. Still nightmares of the *ist D eating batteries, especially with the CF micro drive cards!
In summary, the apprehension was unwarranted. The camera feels good, functions wonderfully and I am pleased with the initial results...it's hit on every deficit I believed existed with the K20 when compared to the nameless "others". Al
