11-04-2012, 11:06 AM   #1
Pentax K5 and Vivitar70-210/3,5
Hallo, can you help me? I have Vivitar series 1 70 - 210/3,5 Pentax mount. I want use on the Pentax K5, but I can not put the lens mount. Is there any way to fix this? Thank you Honza
11-04-2012, 11:13 AM   #2
A lot of Vivitars have a shield around the aperture lever that is larger than normal, this interferes with the newer bodies. You can usually remove the entire shield with a couple screws. There isn't really any consequence to leaving this off that I have seen, but if it makes you feel better you can cut it down to the normal size and reinstall it.
Posting a picture of the mount would let us know for sure if your lens has this over sized shield.
11-04-2012, 12:02 PM   #3
Thank you so much it works! I took off my shield around the lever. How to use macro? Should 1:2,2 but I only 1:10. Thank you again. Honza
11-04-2012, 12:20 PM   #4
You have the Kiron made one with a serial number that starts with 22? I there is a button to allow it to go into macro mode, put the lens at 210mm, press the button and turn it until the macro line lines up with the red dot, then the zoom becomes focus. At 70mm on the zoom scale it should be at maximum magnification.
11-04-2012, 12:23 PM   #5
I know it:-)) Macro OK. Thank you again. Honza
11-05-2012, 01:06 AM   #6
I would like to ask. Komine also has a macro lens on 70mm most? I have Kiron. Focusing distance of about 50mm. Than you Honza
11-05-2012, 01:17 AM   #7
The Komine works differently, it just has more focus travel in the 100 and 210mm range. I haven't used a Komine and Kiron side by side, I only have the Komine at the moment.
11-05-2012, 01:34 AM   #8
I send interesting pages.
Page 37
camera, dslr, k-5, k-5 ii, k-5 iis, k5, mount, pentax, pentax k-5, pentax k5
K10D and Access 70-210 mm 3.5 dchemist Pentax SLR Lens Discussion 18 02-03-2018 09:28 PM
For Sale - Sold: Pentax P30T, MZ-7, 28-75 3.5-4.5, FA 28-80 3.5-5.6, F 70-210 4-5.6 brofkand Sold Items 2 07-11-2012 07:12 PM
For Sale - Sold: FS: Vivitar 28-210 Macro zoom f/3.5-5.6, Pentax P5 hinman Sold Items 11 01-03-2008 07:57 AM
Pentax-A 70-210/4 vs Tamron SP 70-210/3.5 Teja Pentax SLR Lens Discussion 2 01-26-2007 02:09 PM
All times are GMT -7. The time now is 08:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
