Originally posted by regor That is good, and I can't argue with that, tx for sharing the result of your efforts. Then I'd like to know: is it significant enough that it can be seen (or generally felt) on a poster size print ? That's really what it comes down to for me as far a resolution goes (though it seems the absence of AA filter "may" also have an effect on PF). What's your thoughts ?
First, sorry for the slow reply. Second, these are of course my opinions; ones resting on my subjective sense of what is good, proper, etc. So everyone is going to have to do their due diligence before shelling out cash for any camera.
Technique and vision are so much more important than the difference in apparent or actual detail and sharpness between the 5II and 5IIs that it becomes pretty trivial which camera you choose. A powerful, well executed image from either camera would be just as powerful and impressive from the other. Of course, that assumes that the person who created such a good image is able to deal with the softer (and ever so slightly less detail rich) 5II image in post processing, or color and moire artifacts in the 5IIs. If one has a lack of confidence in being able to deal with either problem in the digital darkroom, then they should choose the camera that gives them the image that is easiest for them to deal with.
Would you be able to tell the difference in a poster sized print? Personally, I think yes. But being able to tell and being a
worse, and especially
bad, print, are entirely different things. I just had a chance to show a few photos at a local community art fair. I was really surprised by one particular photo of someone's dog running along the beach. It was SO OBVIOUSLY low resolution that you would have had to be blind to miss it. It was, to put even a finer point on it, HORRIBLY low resolution, printed to about A4 (297 x 210 mm), and looking from a "normal viewing distance" didn't help. And you know what? It was
still a good picture. As a photographer, it was
sad that it was so low res, but it was very far from ruining the photo. The color, mood, and even the pixelated "detail" still carried the image.
I personally have settled on the IIs, but I wouldn't fault anyone for choosing either version.
So, those are my thoughts. It's up to you to decide whether it is worth $0.02 or not
