Originally posted by pinholecam This is nice work, but I'm really apprehensive of the work that needs to be done just to match up the K5IIs o/p.
Can you help to elaborate if this is a fixed setting that I can always apply or a 3-5min per file type thing that I need to do by adjusting parameters for each photo?
Hi pinholecam,
The only thing I did to the K-5 II image was deblur it.
ie. using Topaz Detail takes aprox. 20 seconds start to finish using a preset which I created called "AA Filter deblur". Though if someone were to do this manually, that would involve moving a slider 4 points to the right and pressing apply.
As for Raw Therapee, I didn't do any adjustments whatsoever to either file. I merely used the software to carry over the RAW into Photoshop.
The K-5 IIs image on the other hand, doesn't need any adjustments whatsoever. It's essentially good-to-go straight out of the camera, and so there's that to consider.
Having said that, imo. the K-5 II would have no problems keeping-up with the K-5 IIs with the help of a deblur tool such as the one used here. Though a person might get away with using alternative solutions such as Raw Therapee's deconvoluted sharpening, if they didn't want to invest in added software etc.
Quote: One more suggestion is that perhaps you can check on this IIs vs II thing in another way.
Say the IIs o/p has saved me 1 step of PP 'mileage' since I don't need sharpening (or can use less strong settings).
So in a real life landscape or other application, I could do WB>tweak exposure>Levels/Curves>shadow recovery> saturation > denoise > sharpen.
How would II and IIs compare in such 'real world' applications where such parameters are often tweaked?
The IIs in theory would be able to be pushed a bit more or end up with less noise since it skipped the sharpening step (or needed less).
The first thing I'd mention with regards to this workflow is where NR would be better placed first and foremost in your workflow. That is to say, that it's best to apply NR from a neutral file(0,0,0) and proceed to make your adjustments afterward, rather than after the fact. However, I'm going to venture that the K-5 IIs may hold the advantage here given that the files will contain more detail(sharpness) than the K-5 II which inevitably play's a major role in detail recovery. Whereas the K-5 II will likely work in opposition to this. That is to say that the initial detail lost in the AA filter will likely be compounded by the noise reduction process. - Though, I'd also mention that this is entirely theoretical as I haven't tested this myself, and so I could only call it an educated guess at this point.
Hope this helps.
