12-14-2012, 01:22 PM   #1
FrancisK7's Avatar
Using K5 as a fancy webcam?
Is this at all possible for the rare moments I'd like to Skype with a loved one in HD???
12-14-2012, 01:39 PM   #2
I don't think so, because someone would have to write a driver that supports that kind of functionality.
12-14-2012, 02:19 PM   #3
Anvh's Avatar
It overheats in 10 minutes so not really useful as webcam if it works....
12-15-2012, 11:14 AM   #4
It's possible: I was interested in the same thing a few years ago, but it never happened because I couldn't justify the price for the hardware.
Basically you use the HDMI output of your Pentax camera and connect it to an HDMI input card on your pc. I haven't tried it myself, but from what I remember reading, a company named Blackmagic manufactures these pci-e cards. It should be possible to use it as a webcam or stream it on the web if you want. It's quite an expensive solution and I think you'd be better off with a good webcam for the price.
I remember I couldn't find a driver to use it directly via USB. As Adam pointed it out, you need someone to write a driver for that. I believe this has been done for some Canon models if I remember correctly.
12-15-2012, 11:18 AM   #5
boriscleto's Avatar
It would be a lot cheaper to just buy an HD webcam...
Newegg.com - AVerMedia AVerTV HD DVR MTVHDDVRR PCI-Express x1 Interface
12-15-2012, 11:38 AM   #6
FrancisK7's Avatar
Too bad. I figured if my K5 could record HD video it could just be used as a webcam too but like boris suggested I might as well get a HD webcam
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
New K5 with 18-135WR lens. Pictures are as sharp as a bowling ball. Help? KPrime Pentax K-5 & K-5 II 29 08-21-2012 05:41 PM
Using the K5 as a semi-pro video camera pentaxmz Pentax K-5 & K-5 II 26 05-09-2012 05:52 PM
Using a Vivitar flash 3500 on a K5 Den Troubleshooting and Beginner Help 3 01-21-2012 10:57 AM
W90 as webcam crossmr Pentax Compact Cameras 0 04-10-2011 03:38 AM
K7 and K5 using iPOD Touch as a viewer? jpzk Pentax Camera and Field Accessories 14 12-20-2010 01:13 PM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
