Originally posted by RonHendriks1966 Your SR probably isn't working proparly since it doesn't know that it is a lens with a max off 350mm instead off 250mm (if I'm not wrong).
I was going to suggest that as well (if you review the images in-camera it should tell you the recorded focal length...if at the long end with the TC attached it says 250mm then SR isn't going to be working properly). You'd either have to enter FL manually (not sure if that is possible with a non-manual lens?) or turn SR off and make sure to use fast enough shutter speed (likely 1/500th or faster at the long end).
