12-29-2012, 02:40 PM   #1
LX strap lugs on DSLR
i am new to my K-5 and this forum; and i am a long-time LX fan. i alway thought that the LX strap lugs are fabulous. they allow quick removal of the strap when you don't need it. so i already miss these on my K-5.
now the question: has anyone researched the possibility of installing LX lugs on K-5 or similar Pentax DSLR?
12-29-2012, 04:29 PM   #2
Ole
Ole's Avatar
The lug holders on the K-5 can be unscrewed. You could try if the LX lug holder would have the same thread and fit.
Be careful, though. I fear that the lhe lug holders are just screwed into the polycarbonate inner body, not into metal.
Please report back!
12-30-2012, 07:54 AM   #3
tabl10s's Avatar
I don't think it'll work. The lugs are screwed into retainers that are attached to the body.
01-03-2013, 09:28 PM   #4
more input please
Ole: thanks for the encouragement. but i am concerned about attempting to remove the lugs from the K-5 since i have never done this before and i am concerned about botching it up and jeapordizing my warrantee. Do you know if they remove easily; have lock-tight; right-hand thread?
tabl10s: thanks for the input, but i do not understand what you mean. if there are retainers (in the plastic part of the body?) and the lugs are screwed into the retainers, couldn't the lugs be unscrewed? are you concerned that the retainers are not held in well enough to survive the unscrewing process?
btw: i don't have to remove the lugs from my LX. i bought several spares many years ago.
01-04-2013, 02:12 AM   #5
tabl10s's Avatar
I had both of my LX's for 31 years(still have one...somewhere)and didn't know they were removable till a couple of months ago. Upon close inspection of a removed lug(pic), it seems that the female retainer has been securely fastened to the main chassis and would be very hard to remove.
01-04-2013, 09:09 AM   #6
Ex Finn.'s Avatar
QuoteOriginally posted by pentaxdevotee Quote
You all might want to look at this diagram before unscrewing stuff.
The parts circled in green are the strap rings. The hardware circled in red are the nuts and washers inside the top cover, holding the strap rings in place. In order to replace the rings, you must disassemble the top cover of the camera.
One picture is worth thousand words. (pictured is a K7, same as K5).
Cheers.
01-05-2013, 11:10 AM   #7
thanks to both tabl10s and Ex Finn.
Ex Finn the image you provided is the clear info i needed. the nuts on the inside prevent easy removal of the strap lugs.
i will have to work on a different method for quick removal of camera strap.
it is mind bogling to me that Pentax did not continue a great idea in all their cameras after the LX: quick release strap connection.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lugs, lx, lx strap lugs, pentax k-5, strap
camera strap lugs? Douglas_of_Sweden Pentax Medium Format 2 10-02-2012 10:06 PM
Wanted - Acquired: Pentax LX Strap Lugs Albino_BlacMan Sold Items 4 06-20-2012 08:01 AM
Where to get LX Strap Lugs? Albino_BlacMan Film SLRs and Compact Film Cameras 8 06-20-2012 07:57 AM
6x7 Strap Lugs Andy21 Pentax Medium Format 13 12-25-2011 12:40 PM
All times are GMT -7. The time now is 05:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
