Battery Care?
Hello Daveej,
My understanding of LiPo batteries is that they should NEVER be completely depleted. Whatever device they are used in, will have a cut-off before this can happen. A spare battery is good insurance either way.
Having said that, LiPo's also don't have a "memory" problem like NiMH and older "round" batteries, either. In other words, with some older batteries, if you ran them down 1/2 way, then re-charged, they would begin to "remember" the 1/2 charge as their full capacity and refuse to run or charge further. You now had 1/2 the original capacity. Lipos won't be fooled this way.
So, you can safely top them off, regardless of how much or little they've been used. The supplied charger will do this correctly.
Never try to get "a few more shots" after shut-down by turning the camera off and on. Change batteries, buy a battery grip, stop shooting.
I believe you can leave the battery in the camera for extended periods, but if you're storing the camera for more than a couple of months, I'd pull the battery and store it safely. Make absolutely sure nothing conductive can touch the two metal contacts, tape or plastic covers should work. A short circuit with a LiPo is a very real potential fire hazard and nearly impossible to put out at the source. There are thick ceramic pots sold for just this purpose (storage).
Hope this helps!
Ron
