Hi all,
I encountered a couple of problems with my K5-II yesterday that may or may not be related. I was taking shots with my Sigma 150-500 on my K5-II with battery grip (and second battery) when suddenly it stopped focusing and then although the display was still on, the camera wouldn't function at all. If the display wasn't still on I would have said the battery had run out, but the battery gauge was showing full.
I removed the grip and transplanted the battery from the grip directly into the body and straight away the camera came back to life. I checked the settings and I had the battery management set to 'Auto' - so it should have continued the use the other battery. Anyway, I put the battery from the body on to charge, put the battery grip (now without a battery in it) back on the body and went back to some shooting. I was doing some macro shots and wanted to use the live view, but when I pressed the LV button the camera locked up solid - no focus no button or wheel function, lcd display still showing and even when I turned the camera off the display stayed on for several seconds. When I turned the camera back on it would function normally until I pressed the LV button and then the lock up would happen again. However, once I took the battery grip off and tried again it worked perfectly.
It seems to me as though there may be some problem with the grip, has anyone else encountered something like this?
'Confused' Vormulac.
Reason: Typo
