Originally posted by chromo Of course we're not just talking photo count, but also the fact that the camera is continuously on.
Well, if you feel like getting Excel out, you could do a chart showing the rate of camera battery depletion per shot taken. Axis X might be 'Battery Voltage', Axis Y might be ' Number of shots'.
Try a short run of say 100 shots on the self-timer, shooting just JPG's and with all battery optimisations enabled (top LCD off etc). Then open the starting JPG and each subsequent JPG (or 1 in 5 JPG's, whatever) in
EXIFTOOL, and average the value of the entries (there are usually 4) for "Body Battery Voltage" in the image EXIF. Put the values for all shot images into Excel and produce a chart showing the rate of battery depletion from shot 1 to shot 100.
Then extrapolate out the rate of battery depletion shown in the voltage drop for those 100 shots in order to get an estimate of how long the camera will take before it dies, assuming it stops working at 0 volts.
The EXIF also has a simpler reading for "Body Battery State", which seems to just have text values like 'Close to Full' that may not be very useful in Excel but which may also give you a simpler way of reading the battery state (I guess) from image 1 to image 100.
