Originally posted by JimJohnson To be frank, I am guessing based on other Pentax compatible IR remote releases....
With all Pentax IR remotes, the only button that performs the same function on all IR release equipped Pentax cameras is the shutter release.
The zoom button is only functional on Pentax Point & Shoot cameras with a powered zoom feature. On current Pentax dSLR cameras it either does nothing, or may cause the camera to auto-focus.
The Fn button on some remotes is also likely meant primarily for P&S cameras. Again, on current Pentax dSLR cameras it either does nothing, or may cause the camera to auto-focus.
Personally, I have always gone into my camera's menu and linked AF to shutter release when using an IR remote so one button does it all. If I don't want the camera to re-focus, I pre-focus then switch the lens to manual focus before using the remote. It is a lot faster than switching the menu settings and I never have to worry about what settings are currently in place. After losing a more expensive IR remote, I paid US$1.88 for my last IR remote (with only one button) and it works just as well (or just as poorly depending on your circumstances) as more expensive IR remotes. Based on the local cost of purchasing a replacement button cell battery, it is less expensive to just replace the entire remote.
Thanks - very helpful information indeed. Wow, the IR remote is really cheap ($1.88); what IR remote is this and where do you get it from?
