07-10-2013, 09:03 PM   #1
Motion Lens for K-5
What is the best lens for capturing animals (Dogs, Birds, Deer, etc.), in motion? Preferably one made by Pentax if possible, but open to all answers.
07-10-2013, 09:23 PM   #2
rbefly's Avatar
Stop-Action?
Hello RyanGilbert, Welcome to the Forum!
There are two main factors when considering a lens for a particular purpose;
One, focal length. That is, a wide-angle lens of 20mm will show a long view lengthwise, but objects will appear smaller or further away than normal.
A standard lens of 28-40mm will approximate the human view, both vertically and horizontially. A 'normal' view.
A telephoto will offer a more narrow point of view, but will enlarge objects and bring faraway object 'closer'.
For sports, wildlife and distant shooting, a telephoto of about 100mm to 300mm is generally used. This can either be a prime (a single focal length, like 100mm) or zoom (Variable focal length, like 80-200mm).
The second factor is called lens 'speed'. This describes the maximum aperture, the greatest amount of light the lens will allow. 'Fast' lens (smaller aperture numbers, like f/1.8, f/2.0, f2.8) let in more light, therefore a faster shutter speed can be used. This is most important when trying to stop movement.
So, a good 'motion' lens for a wide range of subjects would be an 80-200mm f/2.8 telephoto zoom.
Pentax does not currently offer this size and speed tele zoom, but several aftermarket manufacturers do. Sigma and Tamron are two good choices.
Hope this helps!
Ron
07-10-2013, 10:42 PM   #3
abmj's Avatar
For birds, you want the longest, fastest lens you can afford.
07-11-2013, 04:18 AM   #4
Hello RyanGilbert and welcome from mee too.
There is a great difference between a happy dog sprinting towards you, a deer running away from you and small birds (all birds are "small" when it comes to photography at a distance!) flying around and over your head.. No single lens will probly be "best" for all purposes, but if you want a bit of everything (at least for a start) in one lens, you will have to look for a decent zoom.
While I do not really disagree with rbefly and his reccomendation of an 80-200mm f/2.8 type lens, you should realize that such are quite bulky and heavy beacause f/2.8 requires a lot of glass and then, 200mm isn't an awful lot when it comes to birding. Further, the shallow depth of field at f/2.8 may not always be goofd enough for you. But it is probably the closest you will get with a single lens.
However, you might also consider a cheaper alternative such as the Pentax 55-300mm for a start. I don't have any experiences with that lens myself, but with K-5's fine ISO properties, fast shutter speeds and high ISO isn't quite the same problem as it used to be some years ago. And the K-5's Tav setting can be very useful if you want fast shutterspeeds and a decent depth of field and thus, a wider aperture than f/2.8.
If you are prepared to buy more than one lens, you might consider a set of the Pentax 50-135mm f/2.8 (for dogs and the like) and the Pentax 300mm f/4 or 200mm f/2.8 - but mind you, such a set isn't exactly cheap!
07-11-2013, 04:48 AM   #5
Docrwm's Avatar
Beyond the lens, and the answers you are getting are spot on IMHO, there is the issue of understanding shutter speed and the ability to pan. Panning is a skill that takes practice but it can convert a slow lens into one that can get the shot (and thereby save you a ton of money and give you a great image).
Mastering Panning – Photographing Moving Subjects
07-11-2013, 05:03 AM   #6
klh
klh's Avatar
I would add one more variable - focus speed. To get a good one of the dog, for example, one needs an accurate and fast focus mechanism like the DC motor in the 18-135. While that is too short for birding or other wildlife, it is a great lens for chasing kids and pets.
07-11-2013, 06:03 AM - 1 Like   #7
QuoteOriginally posted by klh Quote
OMG, I've been doing it all wrong. I leave the lens attached to the camera and do the chasing myself. It's no wonder my dog is usually out of focus!
And a big New Joysey welcome to you RyanGilbert! Keep reading here on the forum - you'll get great info to improve your technique and a whole gamut of opinions on gear. I glean something new almost everyday. This thread is a case in point. I am quite eager to read Docrwm's link Mastering Panning – Photographing Moving Subjects. I definitely need help with that.
07-11-2013, 09:43 AM - 1 Like   #8
QuoteOriginally posted by rbefly Quote
Hope this helps!
Ron
Thanks Ron, that helps alot!
07-11-2013, 09:43 AM   #9
QuoteOriginally posted by jamarley Quote
Thanks ill give it a read!
07-11-2013, 09:49 AM   #10
TER-OR's Avatar
Also set up a FAST SHOT user mode if you're chasing dogs and kids. It can be useful for birds, too, since they often move quickly
In my experience, the 18-135 is a faster tracker. The 55-300 does OK, but often doens't catch the dog running toward me as well as I'd like - that's a tough target.
For birding the 55-300 is my longest lens, and it's OK. You're going to get lots of branches in focus if that little warbler is zipping around...
07-11-2013, 03:11 PM   #11
I consider the dog-sprinting-towards-you scenario the toughest of all tracking challenges. I've never pulled it off successfully, I always get the tail sharp, never the head. So prepare to be disappointed.
For sports and AF-C, I think I'd recommend something like a Sigma 50-150/2.8 non-HSM (the old one that exists in Pentax mount). Sigmas generally have short focus throws that yield fast AF. The Pentax 50-135 (which I have) is decidedly slow focusing and I don't like it for AF-C (otherwise it's fantastic, arguably the best Pentax zoom ever).
Regards,
--Anders.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, motion, pentax k-5
K-5 motion blur from IS? Jeff Charles Troubleshooting and Beginner Help 29 06-05-2013 01:20 PM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
stopped motion with motion at a bar help no694terry Photographic Technique 9 10-20-2012 10:26 AM
New firmware: v1.13 for K-5/645D, v.1.12 for K-7/K-r, v1.03 for K-x Adam Pentax News and Rumors 71 05-15-2012 01:42 PM
Need advise for lens collection for K-5 gopentax Pentax SLR Lens Discussion 10 04-04-2012 01:55 PM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
