Originally posted by Reptilezz 200 photos im left with 10 or so
Yeah, that sounds about right for birding
Originally posted by Reptilezz The only way i can get the settings i used is from the camera because it doesnt show on my flickr
If you know the focal lengths you use the most, you'll have an easier time deciding. [Edit I see you have a S2IS] Unless you feel limited by the reach, any xx-300 zoom wil do just fine. If you get a 70-200 2.8 you are sacrificing a bit of range, but getting a lot better lens (also, the 2.8 aperture) which would enable you to crop more.
Your S2IS: eq. 36-432mm
55-300 on crop: eq. 80-450mm
70-200 on crop: eq. 100-300
