10-01-2013, 11:04 AM   #1
Neville's Avatar
When to use the green button?
I'm trying to figure out what the purpose of the green button is on my K-5II.
When would it be useful to use it?
10-01-2013, 11:20 AM   #2
WightWalker's Avatar
If it's the same as the K5, then when pressed it will re-set the exposure.
Handy if the setting are miles away from a correct exposure; the re-set settings may not be the desired settings which allows the user to adjust to suit.
10-01-2013, 11:34 AM   #3
QuoteOriginally posted by Neville Quote
QuoteOriginally posted by WightWalker Quote
That's basically it. I generally only need to use it with manual lenses, which is when it really comes in handy as it allows the camera to shop-down meter.
10-01-2013, 11:37 AM   #4
In M mode you can press green button to automatic set exposure and shoot semi-auto. In Hyper P mode when you press green button you`ll reset mode to P.
10-01-2013, 11:53 AM   #5
It's also a "center" or "zero" button in all sorts of screens such as white balance GMYB adjustment, jpeg settings, flash exposure compensation, ordinary exposure compensation. And it turns on auto ISO.
Regards,
--Anders.
10-01-2013, 11:56 AM   #6
kiwi_jono's Avatar
+1 very useful in hyper P mode - takes you back to regular P mode.
I use P mode most of the time now because it effectively gives you Av and Tv while having the P for quick shots.
10-01-2013, 12:54 PM   #7
QuoteOriginally posted by kiwi_jono Quote
+1 Here - really handy that you can switch between modes that way.
But first and above all, I appreciate the green button for use with all my vintage lenses. Here, it has more or less the same basic functionality as the metering needle in my K1000 film camera.
10-01-2013, 01:58 PM   #8
I've set my K-7 green button as back button focusing and disabled the AF on ½ shutter-press. I assume this is possible with the K-5II as well.
10-01-2013, 05:23 PM   #9
Bruce Clark's Avatar
I really appreciate this question as it prompted me to remember something I had forgotten. Having had the K-7 in for clean and adjust. all the settings came back as factory default. Of course I had forgotten to reset this function. Anyawy I prefer to set aperture and adjust other setting around that and with my manual lenses setting the Green button to Tv Shift in M Mode (C>4>28>2 in the K-7) gives me proper shutter speed for any given aperture and ISO. But as other readers have pointed out it has many uses depending on your preferred style.
10-03-2013, 06:19 PM - 1 Like   #10
abmj's Avatar
Interesting answers in this post. I can honestly say that I have never used the green button. I guess it is the old-time film shooter in me but I always set my own settings. The green button is just something to avoid touching accidentally.
How can I set the Green button to go to Monochrome? jon404 Pentax K-01 2 02-18-2013 11:25 PM
When to use the X mode? jatrax Flashes, Lighting, and Studio 10 01-13-2012 01:20 AM
Green button best use? suenalex Pentax K-r 11 11-04-2011 09:17 PM
DOF, The Green Button, When, How, Why Deiberson Troubleshooting and Beginner Help 14 02-21-2010 03:16 AM
When to use the AE-L button? atyab Pentax DSLR Discussion 10 01-01-2009 03:27 PM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
