10-07-2013, 10:26 PM   #1
tabl10s's Avatar
Is Stop-Down Metering...
really needed with manual lenses? I took pics with my K85 1.8 didn't the use the green button and got great results.
10-07-2013, 10:29 PM   #2
QuoteOriginally posted by tabl10s Quote
really needed with manual lenses? I took pics with my K85 1.8 didn't the use of the green button with great results.
Yes it is, if you're actually changing the aperture and not keeping it on F1.8. Otherwise the camera assumes the lens is wide-open.
10-07-2013, 11:42 PM   #3
carrrlangas's Avatar
Green button is a good starting point if you donīt know what the settings should be approximately.. Then fire and chimp, adjust and good to go
10-10-2013, 11:32 AM   #4
I donīt understand...
When I put my M 35/2 on f8, and press the green button - the camera stops down and adjust the time so I get a (generally) well-exposed picture.
So, it stops down, meters and sets the time.
But are you saying something else?
Jon
10-10-2013, 11:37 AM   #5
paulh's Avatar
QuoteOriginally posted by Jon Petersen Quote
Jon
You are using the green button correctly. If you don't then the camera will assume the lens is wide-open no matter what aperture you've set. This applies to the K & M (fully manual) lenses.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
stop-down metering with MX Alx Film SLRs and Compact Film Cameras 10 05-20-2014 05:30 PM
Stop Down metering on K-30 ticoun Pentax K-30 & K-50 16 09-05-2013 04:00 AM
Does Stop Down Metering Apply CMG Pentax K-5 & K-5 II 14 08-22-2012 09:25 PM
K20 manual stop down exposure metering Mike C Pentax DSLR Discussion 5 03-07-2012 08:20 PM
Stop down metering on a PZ-1p blackcloudbrew Film SLRs and Compact Film Cameras 2 11-03-2011 02:01 PM
All times are GMT -7. The time now is 11:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
