02-10-2014, 02:02 PM   #1
SB 24 for k5
i understand that this flash had a sensor build inside so does this work automatic on my k5 i don't need hss cuz i only use flash indoor so is this a good choice ? i wonder can i go trigger happy with this flash without set the flash manually ? thanks
02-10-2014, 02:06 PM   #2
QuoteOriginally posted by DuyNguyen Quote
No P-TTL means no easy mode (P) shooting, but as you said the flash should work just like any other auto flash.
More info here:
https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/57808-nikon-...-use-k20d.html
02-10-2014, 02:32 PM   #3
so this is a ideal flash for my low budget right now ? i have a yn560ii, can sb 24 work as main flash and yn as a slave ?
02-10-2014, 06:10 PM   #4
They will work great together, the Yongnuo in S1 mode will trigger optically from the SB-24. The only thing is you'll probably want the SB-24 in manual mode if you're using the Yongnuo too, auto mode with multiple flashes doesn't work very well in my experience.
02-10-2014, 06:46 PM   #5
thanks a lot elliott
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Using Nikon SB-400 or SB-800 Flash. stevewig Photographic Technique 13 04-10-2013 10:08 AM
For Sale - Sold: Two Nikon SB-24 flashes and a Vivitar 283 geauxpez Sold Items 5 07-29-2009 06:48 AM
Nikon SB-24 or SB-26 flashes ok to use with K20D? bpjod Troubleshooting and Beginner Help 10 04-22-2009 08:17 PM
Nikon SB-24 Speedlight Flash mi2nc Flashes, Lighting, and Studio 3 01-26-2009 04:35 PM
All times are GMT -7. The time now is 10:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
