wombat2go's idea is a good one, and you should give it a try.
For more "serious" work, many people don't consider this reliable enough. That's when you get into something like a wireless Pocket Wizard system. The PW is great if you have to interact with other common equipment - for example, almost any artificial lighting class you'll ever take will be using one.
But if the system's entirely up to you, you can go with something cheaper. I have a Paul C. Buff CyberSync system, which I like because my Einstein strobes have a built-in slot for an inexpensive wireless transceiver that can even be used to remotely control the strobe's settings if needed. So I can use my transmitter with a combination of the Einsteins and my Pentax flashes.
Paul C. Buff - CyberSync
I believe there's also at least one TTL capable "small-name" lower priced dedicated system for Pentax now available on Amazon. Perhaps someone else who owns one can refer you to it.
