06-06-2014, 06:48 PM   #1
Flashing Red Light
I'm out of town and don't have my manual.. Anyone know what the flashing red light on the back to the right of the green button means. FYI, my autofocus started acting up about the time I noticed it, battery is down 1 bar but never been an issue before. K5IIs
06-06-2014, 07:10 PM   #2
jatrax's Avatar
According to the manual it is "self timer lamp/remote control receiver"
Hope that helps....
06-06-2014, 07:15 PM   #3
Tako Kichi's Avatar
If nobody else replies you can download a PDF manual for the K5IIs here:
Support?RICOH IMAGING CANADA
You can read it online too if you can't download.
EDIT: Ooops Jatrax got in while I was searching for the link.
06-06-2014, 07:26 PM   #4
rbefly's Avatar
Remote?
Hello JR,
I've found that annoying blinker a couple times myself. It's an indicator that the remote is activated (the clicker, not cable release) or the timer delay is on.
On the circle control dial, top icon is the clock. Press that and you'll see a series of icons, single frame shooting, hi-speed, 2s delay, remote, etc.
Move the green highlight to the far left; single frame shooting, no remote, no timer. Press OK.
That should do it!
Ron
06-06-2014, 11:34 PM   #5
Thanks for the replies. Yes, I was using a remote day before yesterday and never changed back. That explains a lot. Thanks again.
11-08-2018, 03:55 AM   #6
Ha! I had the same problem. I got that blinking light, and could not turn it off. And a power cycling did not help. Googled it and ended up here. Quite simple actually, but I could not imagine that the remote setting would survive a power cycling.
11-08-2018, 11:43 AM   #7
QuoteOriginally posted by Roland Karlsson Quote
It is one of the settings that endures past a power OFF but will go away with a dead battery, unless you powered off while it was enabled.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, light, pentax k-5
Does this flashing yellow and red have something to do with exposure? rkymtnrider Pentax K-01 6 02-03-2013 09:40 AM
Problems with mirror lens on K-01...red flashing F-- slackercruster Pentax K-01 2 07-11-2012 01:20 PM
Flashing red spot William Troubleshooting and Beginner Help 4 06-06-2012 11:38 AM
red flashing in lcd screen rca1 Pentax DSLR Discussion 5 04-07-2012 11:11 AM
flashing yellow and red in KX trishytee Pentax DSLR Discussion 21 05-01-2010 01:35 PM
All times are GMT -7. The time now is 09:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
