09-29-2014, 11:38 PM   #1
K-5 Acting Up In Program Mode
I like to shoot in program mode when I'm doing street shots. More composing /shooting and less fiddling.
Most of the time the program line works just fine. I usually set it for either deep depth of field (person in front of mountains icon) or the narrow depth of field (person in front of blurred background icon). The past couple of times I've done this the camera seems to go a little nuts after working fine for a while.
First my images start coming out way over exposed. Looking at the LCD screen I see that the camera has now defaulted to AV or another manual type mode. Other times when I use the flash as fill flash the over-exposures happen again. This happens more often than the when it defaults to a manual mode. If I turn the camera off and then back on again everything seems to go back to normal program line again (most of the time) and the fill flash works too (although I have to back it down a bit). Very annoying and lost a number of shots this weekend at a local street festival.
This is not lens dependent. It happens with my kit 15-55 or my sigma 17-70. I usually shoot at ISO 200.
Any ideas about what is happening? What I am doing wrong? Thanks in advance.
09-30-2014, 04:02 AM   #2
Ole
Ole's Avatar
If you turn one of the e-dials when in program mode the camera will go into Av or Tv mode (this is called hyper program). Hitting the green button will reset the camera to the program line.
Could you mistakenly have turned one of the dials?
BTW, how the dials work can be customized.
09-30-2014, 05:50 AM   #3
MSL
MSL's Avatar
QuoteOriginally posted by eddaytona Quote
If you could post one or two of these images (small size is fine) but with the EXIF data intact we might be able to see what happened.
09-30-2014, 03:18 PM   #4
QuoteOriginally posted by Ole Quote
Ah ha! Ole, that's probably the answer. Hitting the green button is a great tip too. Damn, things get so complicated!
MSL: Let me see if I have saved any of the bad shots and I'll post. I'm pretty aggressive in deleting things.
Thanks Folks.
09-30-2014, 05:59 PM   #5
OK, here is an example where the exposure goes nuts after many shots being fine then fine again after turning camera off and on. I tried to use the flash as fill in the overexposed shot and it knocked the speed down to 1/180th vs 1/800
PENTAX K-5  Photo
PENTAX K-5  Photo
09-30-2014, 06:10 PM   #6
Here is another set.
PENTAX K-5  Photo
PENTAX K-5  Photo
10-01-2014, 11:03 AM   #7
MSL
MSL's Avatar
The EXIF data says all these images were shot in Aperture Priority mode, note Program mode.
What is a little odd is that for both the overexposed pictures the shutter speed was 1/180. Perhaps just a coincidence, but this is the upper limit when the flash is engaged. I've had the odd case where I've caused the flash to partly pop up, which isn't enough to make it fire, but where it might trigger the camera to drop the maximum shutter speed. Feel free to post more pictures - they don't need to be large in size as it is just the EXIF data I'm interested in.
camera, dslr, field, fill, flash, icon, k-5, k-5 ii, k-5 iis, k5, pentax k-5, times
My K-x Is Acting Up... magkelly Troubleshooting and Beginner Help 11 03-24-2014 11:26 AM
K-30 acting up with lithium batteries SunValley Troubleshooting and Beginner Help 11 02-21-2014 09:05 PM
Manual mode on my K10D is acting like TAv mode Love my K10D Visitors' Center 9 11-06-2013 11:44 AM
Differences in brightness between consecutive shots in manual mode (K-5) vzbx Troubleshooting and Beginner Help 26 11-13-2012 03:52 PM
K-7 acting up? voyager13 Troubleshooting and Beginner Help 3 09-25-2012 07:21 PM
All times are GMT -7. The time now is 08:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
