When focusing on certain objects, it rotates to infinity and make an electronic noise every time you press the shutter release button, like its trying to rotate past infinity. It will make the electronic noise when pressed and will not try to focus, just stays at infinity. If I zoom in or out on the same object, it will usually focus, then when I go back to the focal length that was an issue, it will properly focus. The issue occurred infrequently at first, now it is happening many times a day. Usually occurs in medium to low light, rarely in good light, but never occurred in these situations the prior tens of thousands of pics. I have tried different lenses, its not a lens issue. The camera has ~75k actuations if that matters.
Any help would be much appreciated.
11/13/2014 Update
It's not the battery, checked with several. Not the lens, same issue on several. But today the issue happened in full daylight, previously it would happen only on interior lower light shots. Also, I noticed that every time there is a auto focus issue, the ring is out toward infinity or past and can't get back but makes a noise like its trying. If I select manual focus and adjust the ring back, then turn AF back on, it works fine until it focuses out toward or past infinity and it just can't get back.
Reason: update
