09-28-2016, 09:07 PM   #1
Can multi-exposure be done with a single shutter press?
Is there any way to trigger the multi-exposure without a new shutter release after each frame?
I've reviewed the K-5 manual. I already have custom function 9 enabled for one-push bracketing but that setting doesn't help multi-exposure.
Multi-exposure gives me a single file for further processing. Alternatively, I can set the intervalometer for my 9 shots, but that fills storage faster and requires additional post processing.
09-28-2016, 11:06 PM   #2
I don't think so (it wouldn't make much sense given the creative goals of that mode). But you could do a single-press 2-frame normal bracketing sequence.
09-29-2016, 03:43 AM   #3
You can always try a flash that triggers multiple flash bursts in one exposure like the RF60. Unfortunately that means you have to use flash, but for some applications it works.
09-29-2016, 09:24 AM   #4
The application I'm thinking of is when I need a longer exposure than possible with ambient light, ND filter, minimum aperture, etc. For example, if I want a one minute exposure but conditions only allow a 10 second maximum exposure, I'd like to combine consecutive shots without needing to do 6 shutter presses.
Yes, I could stack ND filters. That hurts image quality.
Yes, I could carry every possible ND filter with me. That gets expensive and makes it difficult to travel lightly.
This isn't a big deal. I can listen and press the remote immediately after each 10 second subframe finishes. I was just hoping there was a way to automate that - the camera hardware is definitely capable of doing it, it's just that the firmware doesn't allow the option.
Note that I tried holding down the shutter release on multi-exposure. That didn't help; my K-5 forced me to lift and repress the button to fire the next shot.
09-29-2016, 09:34 AM   #5
UncleVanya's Avatar
QuoteOriginally posted by DeadJohn Quote
Isn't that Image Composite mode? The K3 has that as a drive mode and it only takes a single shutter release press but it creates multiple files as I recall. But I might be misremembering.
09-29-2016, 01:32 PM   #6
I'm talking about the K-5. It has a less advanced ancestor of the K-3 image composite. K-5 calls it "multi-exposure", and it's only available via the menus not the drive mode menu.
09-29-2016, 01:33 PM   #7
UncleVanya's Avatar
Yeah I figured. I have used the k-3 feature at night. It is pretty neat.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, multi-exposure, pentax k-5, processing, shutter
Can burst shots be done with flash? philbaum Flashes, Lighting, and Studio 7 10-27-2015 08:12 PM
Can a hybrid DSLR be done? OVF and EVF in one body... kadajawi Pentax DSLR Discussion 27 03-25-2015 05:34 AM
About what can be done with a moving sensor: benefits of being late and cheap... Douglas_of_Sweden Photographic Industry and Professionals 9 10-09-2013 10:42 AM
What can be done with broken aperture blades? yusuf Pentax SLR Lens Discussion 3 01-02-2013 03:38 PM
A Pentax Dream...Can It Be Done? shutterpuppy Pentax DSLR Discussion 11 10-23-2008 09:34 PM
All times are GMT -7. The time now is 09:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
