Originally posted by dewolf I have some difficulty understanding the mechanics of the Program line setting in the Capture menu page 3. Auto, Normal, High Speed etc etc. What dial modes does this affect?
Also Expanded AF area, when used with AFC with select button set. Would this be a better setting for tracking ?
Pentax K5 IIs
Thanks for the clarity
DeWolf
The program line selected will technically affect all semi-automatic modes if auto ISO is enabled, but it has the biggest significance in P mode.
Auto- more or less a black box, does what the camera thinks is best (probably the same as normal in most cases?)
Normal- a general-purpose mode with balanced shutter speed and aperture. Default on all entry-level models outside of a scene mode.
High-speed- prioritizes high shutter speeds, good for sports or potentially when hand-holding
Depth- prioritizes narrow apertures, good for landscapes
Bokeh- prioritizes wide apertures, good for portraits
MTF- prioritizes sharp apertures (i.e. F5.6-F8, works with FA lenses and newer only)
Originally posted by dewolf Also Expanded AF area, when used with AFC with select button set. Would this be a better setting for tracking ?
Technically, yes, but with only 11 AF points it doesn't make much of a difference in practice. In expanded area AF, the camera starts by focusing on the selected point, but can "expand" its focus to one of the other points if the subject leaves the primary point.
Unfortunately, Pentax cameras are very eager to "expand" the focus to a different point without making any fine adjustments, which can result in failed tracking. Practice makes perfect here and you have to learn to understand the camera's behavior/limitations to get good results.
Compare this to auto mode in which the camera can initially focus on any of the 11 points.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
