Back from the Monster Energy Supercross Event held in the Rice-Eccles Stadium at the University of Utah in Salt Lake City.on April 22, 2017. Had a great time and was able to bring back some halfway decent pictures out of the stands.
The camera used was the Pentax K5iiS. The lenses used were the 18-135mm zoom and the K 200/2.5 mated to the Pentax AF 1.7x adapter/teleconvertor. Other than taking a few photos during local racing events, this is my first foray into the professional world of Supercross Racing. Keeping things relatively short, here are some photographs from the adventure.
First, the son in law explaining to Grandma how Supercross Racing works. This is the 18-135mm zoom.
To allow you to orient yourselves, here is a shot of the stadium while the equipment crew was smoothing out the dirt from the earlier time trials. We were sitting a couple rows above the entrances you see across the stadium, in the middle. This is also taken with the 18-135mm zoom.
Here is a photograph of one of the pretty ladies getting out of the way after displaying the 30 second warning for the start. This was taken with the 200/2.5 attached to the 1.7x teleconvertor for a combined reach of 510mm. This gets you up close.
20 or more motorcycles are all lined up behind some gates. When they drop everybody heads for the first corner, jockying for position. Think horse racing with a lot more noise. I am back to the 18-135mm zoom since the other lens setup didn't give enough field of view to get the sense of the bunch headed for the corner.
Eventually things sort themselves out and someone takes the lead. This is Ryan Dungee one of the number one riders on the Supercross circuit. Another nice and up close shot with the K200/2.5 on the 1.7x teleconverter.
But, there is always someone wanting to pass you. This Eli Tomac, another of the number one riders, challenging Ryan for the lead in one of the corners. This is the corner closest to where we were sitting and most of my best photographs in this corner were taken with the 18-135 zoom. But this was taken using the 510mm combination and I liked how it turned out. I think it gives a good impression of how competitive these racers are.
As things worked out in main event, Eli Tomac eventually took the lead from Ryan and here he is exiting the corner just before the finish line. This was also taken with the 510mm combination. The finish line was on the other side of the stadium and required some reach. I think the K200/2.5 and 1.7x teleconverter did a great job with this photograph.
We really enjoyed the event and I think the K5iis and the two lens combos did a fine job. The 18-135mm zoom focuses very quickly and had no trouble whatsoever locking in on the action. The K200/2.5 is an older K-Mount manual lens but the Pentax AF 1.7x teleconvertor gives a limited amount of autofocus if you prefocus the lens to start with. In my case I just turned the old manual lens to infinity and let the autofocus teleconverter/adapter do the rest. Although it was so tight on the action that it took a lot of work to keep up with the racers, if I did my part I think the lens certainly did its part.
Everything was shot in jpeg and the white balance was on auto. Multi-Segment metering was used. The color was set to Vibrant. The photographs were imported into Lightroom, sharpened a bit, and exported in reduced format for this forum. Nothing else was done. No cropping, no color adjustments, no contrast or other developing work. I set the ISO at 3200 and used shutter priority to maximize the shutter speed as much as possible.
I used spot focus with continuous auto focus and almost all of the photographs came out very clear and sharp. Focusing was very quick with both lens combinations. I never had a problem catching focus with the zoom but occasionally, particularly if I wasn't panning fast enough, the K200/2.5/teleconvertor combo would not catch focus. But this was not an equipment problem, this was entirely a photographer problem. When I was panning with the action the focus was just as quick as the zoom, maybe even quicker.
I started with rapid continuous shooting but shut that off pretty quickly and went back to single frame. I found that I was easily able to capture what I wanted by firing the shutter myself. I know that people worry about shutter lag but I can tell you, from my observation, the K5iiS has very little, if any, lag. At least I couldn't detect any. Once in awhile I was a bit behind the action when I reviewed the results, but that was my doing, not the camera's.
I have almost certainly rattled on enough over this so I'll cut it off here. I would have loved to be on the field in the midst of the action but this worked out even better than I had hoped.
