02-17-2020, 06:27 PM - 1 Like   #1
Using "A" MF lenses on K-5?
l found my first Pentax DSLR here on the PF! Got a k-5 on the way. When you use it with an A manual focus lens, do you put the aperture ring in A and adjust f stop with the body? Or do you set the f stop with the aperture ring when in manual or aperture priority mode? And can you use program and shutter priority when using these lenses? l read about this in the user manual, but don't fully understand.
02-17-2020, 06:36 PM - 1 Like   #2
amateur dirt farmer
pepperberry farm's Avatar
QuoteOriginally posted by camera_nut Quote
l found my first Pentax DSLR here on the PF! Got a k-5 on the way. When you use it with an A manual focus lens, do you put the aperture ring in A and adjust f stop with the body? Or do you set Ythe f stop with the aperture ring when in manual or aperture priority mode? And can you use program and shutter priority when using these lenses? l read about this in the user manual, but don't fully understand.
the first one - leave the aperture ring in 'A' and run the aperture with the camera body...
02-17-2020, 06:47 PM - 1 Like   #3
bertwert's Avatar
Leave the lens on A and then use it like any other lens. Just manual focus, and entering focal length on camera startup.
02-17-2020, 06:48 PM - 1 Like   #4
Sandy Hancock's Avatar
I also leave the lens on the "A" setting and adjust the aperture via the camera body.
All exposure modes will work just like they do with a modern lens - all you lose is automatic focus.
02-17-2020, 08:08 PM   #5
Good. That's even better than using Nikons with manual glass. With 2 or 3 exceptions, Nikon never made MF lenses with electrical contacts.
02-17-2020, 09:20 PM   #6
Kozlok's Avatar
Also with Pentax you get shake reduction with manual focus lenses; I don't believe Nikon offers similar in a DSLR. Mirrorless maybe?
02-17-2020, 09:28 PM   #7
QuoteOriginally posted by Kozlok Quote
AFAIK, Nikon never had a DSLR with SR. You have to have a lens with it.
02-18-2020, 03:14 AM   #8
The Z7 has a built in SR. I didn't check the Z6. It seems built in SR is the new must have, finally after 10 years frowning on pentax cameras (can't work - it's a pentax - no one buys one).
02-18-2020, 07:14 AM   #9
Seeker of Knowledge
aslyfox's Avatar
lots of friendly members
and knowledge can be found here at the forums, if you want to spend the time:
DSLR Compatibility and Usage:
Pentax A lenses work just like modern lenses in terms of metering. All exposure modes offered by current DSLR bodies will thus be supported. Thanks to this, A lenses are much more convenient to shoot with than M and K lenses, though they are all still manual focus.
On DSLRs, the aperture ring should always be placed in the "A" position; not doing so will cause A lenses to behave like M and K lenses. . . .
Read more at: Comprehensive Pentax Lens Guide - Gear Guides | PentaxForums.com
___________________________
Manual Focus Lens Choices for Pentax
That old glass is amazing!
By K David in Articles and Tips on Jul 19, 2015
Pentax users have at their disposal a large variety of Pentax legacy glass, much of it manual focus. We also have brand-new manual focus lenses from makers like Samyang, Zhongyi Optical, and Venus Optics. This article looks at contemporary options, legacy K-mount lenses, M42 mount lenses, and even the uncommon M37 mount lenses. Each type of lens has uses, drawbacks, and advantages that make them good options for different scenarios.
This two-part series discusses manual focuses lenses on Pentax DSLR bodies. This article provides a description of the different manual focus mounts made by Pentax and third-party makers who produce K-mount lenses. The second article in this series will discuss specific manual focus lens uses and techniques.. . .
Read more at: https://www.pentaxforums.com/articles/photo-articles/manual-focus-lens-choic...#ixzz6EJbkTI7u
______________________________________
How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-1, K-3, K-5, K-30, etc)Report Post Like Adam's Post
Posted By: Adam, 08-12-10,
Read more at: https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-m...#ixzz6EJd5nU1G
02-18-2020, 07:36 AM   #10
To be more precise, you could use the aperture ring to something else than A and set aperture with it, but it would be much less convenient, since you will have first to define a setting in the setup once (not really a problem to be fair), but you will have to use stop-down metering with the green button for each shot in M mode, which is both imprecise and quite a hassle, compared to controlled aperture from the body.
02-18-2020, 09:49 AM - 1 Like   #11
Otis Memorial Pentaxian
photolady95's Avatar
camera_nut bought my K-5. I can tell you that the camera is already set up to allow using lenses with an aperture ring. But I'll have to remove my copyright info so you can enter your own.
02-18-2020, 04:59 PM   #12
QuoteOriginally posted by bertwert Quote
You only need to do this when the Shake Reduction system is turned on. If you are using an older zoom lens you will have to keep telling the camera what focal length you are currently using. Another benefit of entering the focal length into the camera when using lenses that don't automatically transmit it is that it will show up in the image's EXIF data. Modern primes and zooms tell the camera the FL.
If you are using a tripod you'll want to turn SR off. If you are using a monopod, opinions vary. If you are using a shutter speed that is at least as fast as the reciprocal of the focal length (1/100 sec. for a 100mm lens) you may not need SR on. I tend to use faster shutter speeds (1/200 sec. for 100mm lens) if I have SR off, but that's just me.
I love my K-5IIs
02-19-2020, 12:16 PM   #13
jack002's Avatar
Setting your lens to A and use the camera to set aperture. The only reason I can think of to not do that is maybe you're old school and like using the aperture ring on the lens manually?
04-19-2021, 06:21 PM   #14
jjbacoomba's Avatar
Thanks for the tips. I just got the K5iis and look forward to using my older lenses.
aperture, camera, dslr, k-5, k-5 ii, k-5 iis, k5, lenses, mf lenses, pentax k-5, priority
A rare pair! MF and MF-1 rosettaquarrier Pentax Camera and Field Accessories 12 08-31-2018 09:42 PM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
What does the DSLR do with the focal length info when using MF lenses? Ari Freund Pentax DSLR Discussion 15 02-25-2010 07:38 AM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
