04-25-2021, 01:18 PM   #1
i_trax's Avatar
K-5lls and time glass
Dear All,
What would be the fastest SD card currently available to work with K-5lls?
Now with more modern Pentax's coming up I am finding a bit annoying to wait 4+ sec for the image data to be recorded onto the SD card while watching the time glass.
kind regards
jack
04-25-2021, 01:38 PM   #2
boriscleto's Avatar
It doesn't have UHS support so the fastest write speed is 25 MB/S, if it supports high speed, otherwise it's 12.5 MB/S.
04-25-2021, 03:00 PM   #3
A C10 standard card would be fine, regardless of UHS category.
04-26-2021, 02:00 AM   #4
I use the 95 MB / s sandisk, it is not worth using them faster, since the read / write speed of the camera is slower.
04-26-2021, 06:12 AM   #5
As previously mentioned, the write speed of the K-5 IIs is likely to be the limiting factor, unless the card is very slow. Pleased bear in mind that the advertised speeds for SD cards is usually the maximum read speed, so you will need to check the detailed specs to find the write speed. Often this is considerably lower, as in the case of the Lexar Professional 633x cards, which have a maximum read speed of 95 MB/s but a maximum write speed of 45 MB/s. These are also burst numbers, as the minimum sustained write speed is only 10 MB/s.
04-26-2021, 07:52 AM   #6
i_trax's Avatar
so to summarise , you can use any SD C10 , UHS or UHS l , U1 or U2 ?
Or U3 and V30 - are they also compatible with this camera?
Any better brands?
I have combination of those:
Pulse Media HC C6
HoodMan HC I , U1 , C10
SanDisk HC I , C4
SanDisk HC , C4
Kingstone HC , C4
SanDisk HC I , C10 , 30MB/s
SanDisk HC I , C10 , 40MB/s
SanDisk HC I , C10 , 80MB/s
SanDisk HC I , U1 , C10 80MB/s
SanDisk HC I , U3
SanDisk XC I , U3
Could someone knowledgable possibly categorise them please.
There is practically not much info online available.
What to use with what?
Or it does not really matter?
I have also one on order for K-3III for slot 1:
SanDisk XC II , U3 , C10 300MB/s.
04-26-2021, 08:06 AM - 1 Like   #7
Bad Boy's Avatar
Settings like lens or highlight / shadow correction could be what is slowing your camera down. Turn them off and see if that speeds things up.
04-26-2021, 10:47 AM   #8
Crooski's Avatar
What Bad Boy says, turn off all camera corrections.
04-27-2021, 07:09 AM   #9
i_trax's Avatar
I located one more
QuoteOriginally posted by i_trax Quote
Any better brands?
Pulse Media HC C6
SanDisk HC I , C4
SanDisk HC , C4
Kingstone HC , C4
SanDisk HC I , C10 , U1 , 45MB/s
SanDisk HC I , U3
SanDisk XC I , U3
I wish , manufactures would simplify and standardise the classification of the data storage cards.
camera, card, dslr, glass, k-5, k-5 ii, k-5 iis, k-5lls, k-5lls and time, k5, pentax k-5, sd, time
PENTAX new glass-old glass - lens tubes designed like old glass? corporate identity? camyum Pentax Full Frame 3 09-24-2017 02:52 PM
Lightroom Camera Calibration profiles for K-5lls djam General Photography 13 11-15-2015 07:08 AM
K-5 ll, K-5lls firmware v1.04 Den Pentax K-5 & K-5 II 1 04-20-2013 08:44 AM
Just ordered a K-5lls Harish Hegde Pentax K-5 & K-5 II 7 11-16-2012 01:16 AM
All times are GMT -7. The time now is 03:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
