Originally posted by pentaxian78 Standard Pentax ones for both. I will double check but believe the OS on the lens is turned off.
OK: Its the OS version. The OS sucks battery power even if switched off! A known side effect.
So it could be the batteries. I would buy a cheap no name just to check.
If it turns out to be the battery, then get originals again.
After 10000 shots and such a lens the batteries can be low but the status might still show o.k.
Often it turned out with problems like yours it was just the batteries.
One just has to search.
There is another simple solution: The external Powersupply.
https://www.ebay.com/itm/272008761566?hash=item3f54fc50de:g:okoAAOSwFnFWFPvf
