08-04-2022, 10:39 AM   #1
Focus problem K5iis
Haven't had the camera out for a while. Today I can only get it to auto focus with the AF button on the back. Tried 3 different lenses. Same issue. In manual focus mode I do not get a green hexagon confirmation on focus. I do get a green hexagon focus confirmation with the AF button. But I do not get auto focusing by pressing the shutter down halfway. Did I screw up a setting or is it the camera?
08-04-2022, 11:59 AM   #2
Oldbayrunner's Avatar
Check menu.....record mode 5/button customization....... Enable AF selects the back button AF shutting off the shutter half press. Disabled enacts shutter half press.
For manual if your camera is set to back button hold the button and turn the lens focus ring and see if the indicator lights up..... If set to shutter button half press the shutter button and turn the lens focus ring until the indicator lights up.
If you don't have a manual then here..... https://www.ricoh-imaging.co.jp/english/support/man-pdf/k-5-2.pdf
08-04-2022, 01:48 PM   #3
Thanks. Enable AF was enabled but disabling it, shutting camera power off then on did not enable shutter half press focusing. Turning camera switch to MF and using the lens focus ring does give the green hex focus to come on. Still unable to get back shutter half press auto focus. Must be a mechanical issue with the camera
08-04-2022, 09:27 PM   #4
I had a kr with same issue. Shutter button was faulty. Had to use back button AF. KR not worth fixing but K5iis I personally would.
af, auto, button, camera, confirmation, dslr, focus, k-5, k-5 ii, k-5 iis, k5, pentax k-5
K5iis auto white balance problem robert Pentax DSLR Discussion 11 04-14-2019 08:41 PM
K5IIs SR problem?? interested_observer Pentax K-5 & K-5 II 6 06-08-2016 08:57 AM
Focus, Focus, Focus (or the usefulness of focus charts) GoremanX Pentax DSLR Discussion 31 12-21-2014 11:49 AM
Focus Problem? WHAT focus problem??! alwaysmichellerene Pentax K-3 & K-3 II 16 12-09-2013 02:06 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 03:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
