Originally posted by MiguelATF Quick addendum: after years of shooting mainly DA primes, of the Ltd variety, I'm both surprised and rather delighted by the initial results I'm getting with the tiny, plasticky FA 20-35mm zoom. It appears, as the saying goes, that it punches far above its weight
That is a good lens. No doubt you'll get much good use from it.
As to the aperture ring use, if you have lenses requiring that time-honored but olde-fashioned technology, then at least those lenses are usable, but not without some sacrifice of operation, such as metering options, mode options, and more. If the MF lens does have the "A" setting on the aperture ring, by all means use it, which will open many of these advantages.
We are creatures of habit. I first encountered the use of electronic camera on-body control of the aperture selection upon acquiring my 35mm film Pentax PZ-1p in the late 1990's- my 3rd Pentax SLR over a period of some 15 years. Even though having the 2-wheel controls and not needing the aperture ring, yet the aperture ring was not "crippled" as is the case with Pentax DSLR cameras. If putting one of my old"M" lenses on it, and using the aperture ring to select aperture, if the camera was set to the "P" mode, it would then switch itself to Av operation, setting the appropriate shutter speed. If I had a MF lens with the "A" setting, I could choose to use the aperture ring or not use it and the camera would instantly respond either way. This camera was such a new and strange device to me, I did not even know what "Av" or "Tv" meant! The traditional "aperture priority" or "shutter priority" (preferred), manual, etc were all I knew. At first I found all these new-fangled controls and terms rather off-putting.
But as time went on, I got to wondering as I observed the new camera's functions in action. Very efficient, was my thought as I became more impressed. I had long been aware of the special value in obtaining a constant-aperture zoom lens rather than a variable-aperture one in the same zoom range. The fact of variable-aperture zoom lenses actually changing the aperture value from that set on the aperture ring as the lens is zoomed to a longer FL, a setting of say f/8 would become a value of f/11 etc. Of course, if shooting in an AE mode like Av, the camera would simply change the shutter speed to compensate, as it does also when the lens is zoomed more into the tele range, in order to minimize the effects of shake. But shooting in the Manual mode is a different matter. I wondered, since the aperture could now be set electronically with the camera's own control wheel, if this control could stabilize an aperture that is not wide open when using a variable-aperture zoom lens.
Using my PZ-1p's ability to instantly work fully both ways, I ran some tests, and was amazed and gratified to discover this to be the case- f/8 would indeed remain at f/8 value! It did this because it COULD do it, while the aperture ring was incapable of maintaining aperture value. This was long ago, but I think back then with AF lenses having an aperture ring with an "A" setting, the camera could still give aperture readouts when the ring was engaged. So I could see the aperture change as in f/8 to f/11 etc when using the ring, and not changing when using the camera's electronic aperture control! I ran numerous tests, being careful to turn off AF and train the camera on large expanses of evenly lit surface during bright, cloudless daylight. I even included visual outcome by shooting some slides, which verified a change in exposure when using he aperture ring, and a stable exposure when using the camera's electronic control.
Though not having the PZ-1p's versatility in regards to aperture ring use, using a modern Pentax DSLR, such as your K-5 IIs, you can still test for this advantage for the camera's electronic on-body aperture control very simply. If you have a variable-aperture zoom lens with the "A" setting, especially one have a wider variable range like f/3.5-5.6 or so, first go into camera menus to set "enable" aperture ring use. Then put your mode dial on the Manual setting. You'll need a brightly-lit cloudless day preferably around mid-day, and a large expansive area having the same lighter color and tone, like a driveway for example, or even a lighter toned lawn. Turn the AF off to MF. Have the zoom set to lowest FL which will provide the lens's widest aperture, The lens set to the "A" position. By using the camera's meter indication, set a proper exposure that will also feature a mid-aperture, not wide open at any point along the zoom range. Say that correct exposure will be at f/8 and 1/250 sec shutter speed. Then zoom the lens gradually to the longest FL. The settings should remain stable and the meter should consistently remain centered for correct exposure, even though using a variable-aperture zoom lens! The surface part of the area that fills the frame will be less as zoomed, but should not be different in any other characteristic. Now, select the same aperture by using the aperture ring- in this case f/8, and once again zoom the lens. Now watch the meter indication, which will no doubt now indicate a change in exposure as the lens is zoomed!
These new-fangled changes brought via newer technology, actually do afford us some real advantages! In the case of Pentax, there is also the exclusive Pentax Hyper System. If shooting in "P" mode, for instance, perhaps due to constantly-changing lighting or background, and then a situation arises where you'd prefer a different aperture or shutter speed other than what the camera has chosen, just go ahead and use the thumb or finger dial to select your preference and the camera will simply instantly obey! You are temporarily instantly switched to Av or Tv operation without first having to change your mode dial before making your selection. This is the Hyper Program mode. A touch of the green button instantly restores full "P" mode.
If shooting in the "M" mode, you can use the green button to instantly obtain a meter-centered "correct" exposure. If you'd then rather have a different aperture or shutter speed, first hit the AE-L button to preserve the exposure value, then select your preference of either and the other will follow along to preserve that exposure! This is "Hyper Manual" operation. This green-button ultra-fast setting feature is also an excellent way to quickly spot-meter around a scene to optimize your exposure when using the "M" mode.
These are very efficient Pentax systems for making changes and establishing adjustments on the fly. I was utterly amazed when I first discovered these design advancements, exclusively Pentax, way back when I learned of their appearance on my PZ-1p!
