Originally posted by Hugo Bucussi
I am inclined on the K-5II just to have a safeguard on the faster AF system, but for the £75 difference, I'm not entirely convinced it is worth it.
It is worth it, as there were other good upgrades as well. There were some issues that could be problematic with earlier batches of the original K-5.
Then the main thing is to find a low-use camera that has been well cared for. As to lenses, this is a very important factor also. I too recommend the DA 18-135mm DC WR lens. It is better than the kit lens in every way. Its very versatile and generous zoom range would fit your described uses very well. It covers subjects both near and pretty far. Its AF is exceptionally fast and accurate, and is very quiet. It has WR (weather-resistant) construction and is much better built than the kit lens. The K-5 series is also built having WR construction, but this is not actively so unless using a WR lens with it. If you were to consider Nikon or Canon, for new equipment you would be paying around $1,000+ for the camera body and another $1,000+ for the lens. Of course used would be less, but prices are still not very cheap, especially for the lenses. The Pentax 18-55mm kit lens is decent for a kit lens, but its AF is not always accurate, it is noisy, and it does not have much zoom range for single-lens usage to cover a variety of scenes such as you describe.
Although I have other more recent Pentax camera models, I still have my K-5 IIs, still use it, and still like it very much. It is a former Pentax flagship model, is built very well, and is durable.
