03-24-2014, 07:14 PM   #1666
My favorite lens for sports is the Sigma 70-200 f/2.8 but it's more expensive.
03-24-2014, 08:00 PM   #1667
QuoteOriginally posted by Randy B Quote
The K5IIs is host to the Sigma 18-250. I am gathering Y'all think that we would better served with a Pentax 18-270 or 18-250 than the Sigma lens, is this right?
Those are a little better overall, I think, but most of the time you wouldn't want to use them for action shooting. The Tamron 70-200/2.8 would be a pretty good bet here, since you have the latest bodies with faster screw-drive AF. On older bodies you might be better off with the more expensive Sigma's built-in motor, but on newer bodies the Tamron reportedly does quite well (I wouldn't be surprised if AF performance is slightly better than the Sigma on a K-3 or even K-5 IIs).
03-25-2014, 07:55 AM   #1668
Patty's pictures are almost exclusively wildlife. So the longer lens helps out a lot.
03-27-2014, 06:56 PM   #1669
Shot a few at a track meet this afternoon. Here are some favorites:
04-05-2014, 10:23 AM   #1670
dadipentak's Avatar
Some Girls Lax with the K-5IIs & Sigma 100-300/4. I've got a K-3 and plan to give it a whirl next week but not because I have problems with what I've been getting with this set-up.
04-07-2014, 01:25 PM   #1671
ChatMechant's Avatar
I honestly thought my k-01's AF worked better for moving subjects than my k-5. But then there was the lack of viewfinder.... anyway here's a shot from yesterday's bike jump contest. This guy landed it, btw:
04-09-2014, 02:37 PM   #1672
clackers's Avatar
QuoteOriginally posted by ChatMechant Quote
It's the opposite, ChatMechant.
The K-01 like many mirrorless cameras only has contrast detection AF, which is slow to track.
That's why Sony users prefer the NEX 6 to the top of the line NEX 7 for action, because it also has phase detection.
In your example shot (great pose by your model!), you've only got the bike at the top of its jump, when it's momentarily stationary.
04-10-2014, 11:27 AM   #1673
dadipentak's Avatar
OK, I obviously need help. I've been shooting my daughter's sports (now lacrosse) with the K-5IIs and getting decent results and figured I'd do even better with a K-3. That's not turning out to be the case: I've missed shots due to focus lag and my keeper ratio has plummeted. I shoot AF.S/spot focus, with a Sigma 100-300/4. Maybe the smaller focus points are too small for my inept technique?
04-10-2014, 02:24 PM   #1674
clackers's Avatar
QuoteOriginally posted by dadipentak Quote
Why AF.S instead of AF.C, Dadipentak?
04-10-2014, 03:09 PM   #1675
dadipentak's Avatar
Well I'm old school, I guess--just want to set the focus indicator on what I want sharp and fire. I don't do bursts. Basically, I'm leery of having the camera second-guess me, AF.S has worked pretty well for me. I might give AF.C another try, though.
04-10-2014, 05:14 PM   #1676
Use AF-C, but don't shoot bursts - leave the shutter in single shot mode. It sounds like you want to use the technique where you focus with the rear AF button, but turn off the function where the camera re-focuses when you press the shutter button. You want to use AF-C and follow the subject with your focus point so when the moment's right you can press the shutter and already be focused. In AF-C you should usually continue holding the AF button throughout the process of taking the shot(s).
There are also nuances of new K-3 AF options that others may be able to help you with. I've only used a K-3 briefly for sports (where it performed well) and I haven't ever played with the new AF settings.
04-10-2014, 07:25 PM   #1677
clackers's Avatar
I don't do bursts.
Bursts are a proven sports photography strategy.
Single shot of a key moment that turns out to not be a keeper = 'regret'.
04-10-2014, 11:05 PM   #1678
Difference from the K-5-IIs might be the larger sensor size -- read somewhere that things get more difficult as the image size increases. Increasing the number of focus points should help. Good luck! And post some pix here -- lacrosse is exciting...
04-11-2014, 03:54 AM   #1679
I've found the K-3 AF makes it a more confident sports shooter than the K-5, at least with something like my Sigma 70-200 HSM II. Keeper rate is better, even if the K-3 high-ISO is a bit worse. I shot several hundred shots at a rodeo recently (AF.C, all 27 points, focus-priority, Continuous-Hi, Hold-AF status medium) and there were certainly less lost-shots due to focus than I recall from shooting the same event several times before with the K-5.
04-11-2014, 05:01 AM   #1680
I think the big difference between the K3 and K5/II is in the AF-C department. AF-S the only difference is that there are more points and that they are smaller -- not a big deal when it comes to locking focus though.
bigma, buffer, camera, championship, da*200, detail, dslr, football, football game, frames, game, k-5, k-5 ii, k-5 iis, k5, match, pentax k-5, post, shots, soccer, softball, son
The danger of sports photography mindglow General Talk 10 12-22-2009 06:50 PM
Sports photography help Mann Photographic Technique 36 06-23-2009 12:49 AM
Help with sports/action photography monochrome Pentax DSLR Discussion 31 11-02-2008 03:49 PM
Amateur sports photography...on a Pentax? pixelpruner Pentax SLR Lens Discussion 18 07-13-2008 05:40 PM
Indoor sports photography how to? sglj3 Pentax DSLR Discussion 9 04-24-2008 11:32 PM
All times are GMT -7. The time now is 04:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
