04-15-2012, 10:27 PM   #631
Sage97's Avatar
QuoteOriginally posted by joe.penn Quote
A few U8 soccer pics from two games over the weekend - all shot with the K5 and Sigma 70-200 OS FLD
These soccer pics are awesome. Sure makes my track pics extremely soft and oversaturated. I am learning quite a bit just by looking at the pics on here.
04-16-2012, 01:07 AM   #632
RonHendriks1966's Avatar
QuoteOriginally posted by dadipentak Quote
Nice shooting, Ron--the last one is a splendid portrait!
Yes I like the portrait from Marleen Veldhuis also the most. In black and white because it was underexposed. Somehow the lights went out and I forgot to adjust my settings. So in lightroom I upped the light with 1,5 EV and that with iso4000 is even a lot for K-5. This picture will be used a lot as a sidemark picture to newsitems on Marleen for the coming months.
@joe.penn that is a nice set of soccerpictures
04-16-2012, 09:11 AM   #633
jppp's Avatar
QuoteOriginally posted by 123jippo Quote
Bike race last weekend
K5+Tamron 18-200, jpgs from raw using cameras converter
That's not far from my office and even closer to the local Pentax dealer.
04-17-2012, 07:44 AM   #634
I shot a soccer match using the Bigma yesterday afternoon. I only wish I had remembered to bring my monopod. It did make the Tamron 70-200 seem light when I switched to it when the lights came on. I did have a few more blurred shots but I would expect that with hand holding the lens. I shot TaV mode to control the shutter speed and aperture.
04-17-2012, 08:15 AM   #635
Yeay, you got some issues in the sharpness. I see that your Shake Reduction isn't ready, so that gives some blur. Maybe because of little movement of your camera/lens by you that makes your SR keep working. Nice shots in it. I like #2 and #4 A little dark to my likings.
04-17-2012, 08:21 AM   #636
QuoteOriginally posted by RonHendriks1966 Quote
I'm not sure I had SR turned on. I will have to try checking and shoot again with the SR active. I used shutter speeds around 1600-2000 in the early part of the match and then slower speeds as the sun set. None have really had any PP applied, just minor adjustments in Picasa to get them into a gallery.
04-17-2012, 09:37 AM   #637
VisualDarkness's Avatar
I mostly shoot handheld indoors with the settings 1/450-1/640, F2.8-4.5, ISO3200-12800 and no SR so I can pan when I get the opportunity. Shutter speeds around 1/1600-1/2000 should give you pinsharp shots without SR, are you sure its shutter speed and not ISO?
04-17-2012, 10:15 AM   #638
Brooke Meyer
Guest
Jazz Dance is sort of a sport. Studio rehearsal, went to get familiar with choreography. Fluorescent lighting at high shutter speeds gives color bleed, the way it is. No room to move like a theater rehearsal. In the last photo, I guessed wrong, had camera vertical, missed dancer and got picture of me in the mirror. Unlike my usual SR On, AFS and track with rear AF, I turned off SR, used AFC and tracked kike always. Responded a bit quicker but I didn't see much difference. This week, theater dress and performances.
PENTAX K-5  Photo
PENTAX K-5  Photo
PENTAX K-5  Photo
04-17-2012, 11:13 AM   #639
Brooke I like your first shot! That is a sport also. The last one is funny with you in it
04-17-2012, 12:09 PM   #640
QuoteOriginally posted by VisualDarkness Quote
According to the EXIF data all were shot at 1/1600 f/8 with ISO between 500 and 640.
04-17-2012, 12:49 PM   #641
That is really weird and they should be pin-sharp with those settings. I doubt that a monopod would be any better as your shutter speed is so fast that it will freeze everything. They almost look backfocused on the ones you posted and if that's F8 it's a lot of back focusing.
04-17-2012, 01:02 PM   #642
joe.penn's Avatar
That first image is at 420mm, directly in the "soft zone" of that lens, without any sharpening that is the best that lens will do at that focal length - not sure about the others, didn't peak at the settings on those... (the AF speed could be playing a factor on the more blurred ones)
04-17-2012, 01:07 PM   #643
Is that really true? At such a small aperture? I don't want a Bigma if that's the best it can do that far from max zoom. Still when I look at the grass it looks like the grass a bit behind the players looks way sharper the grass directly in front.
04-17-2012, 01:47 PM   #644
joe.penn's Avatar
Focus speed also is playing a factor in it - if you look at the second picture down, that one looks more in focus but the image is still soft a little - some sharpening in PP can clean this up.
04-17-2012, 01:51 PM   #645
jppp's Avatar
QuoteOriginally posted by GvilleRick Quote
I only shoot hand held with my Sigma 150-500 and for me the problem isn't the lack of monopod. Bad focus is caused mainly by using AF-S instead of AF-C when the subject is moving from the focus point while I keep the shutter button half pressed. That may be the case here as well. In the first picture the girls are clearly moving towards the camera, which is the most common situation for "back focused" football pictures when using AF-S.
bigma, buffer, camera, championship, da*200, detail, dslr, football, football game, frames, game, k-5, k-5 ii, k-5 iis, k5, match, pentax k-5, post, shots, soccer, softball, son
The danger of sports photography mindglow General Talk 10 12-22-2009 06:50 PM
Sports photography help Mann Photographic Technique 36 06-23-2009 12:49 AM
Help with sports/action photography monochrome Pentax DSLR Discussion 31 11-02-2008 03:49 PM
Amateur sports photography...on a Pentax? pixelpruner Pentax SLR Lens Discussion 18 07-13-2008 05:40 PM
Indoor sports photography how to? sglj3 Pentax DSLR Discussion 9 04-24-2008 11:32 PM
All times are GMT -7. The time now is 11:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
