09-27-2010, 04:14 AM   #46
QuoteOriginally posted by ogl Quote
The real buffer of K-5 at Photokina - 7 RAW.
The low mode is 1.6 fps as at PENTAX with 10 RAW.
The comment was made that the cameras varied hugely in the number of RAW files it took to fill the buffer. The impression got at Photokina was that the firmwares are not final and so it is hard to judge based on these cameras.
09-27-2010, 04:22 AM   #47
JohnBee's Avatar
Word seems to be all over the map with reference to this.
One person claims, that a hands review afirmed 14 RAW at Photokina, while another says 7...
I'm hoping for the best but I could live with 2 seconds of continuous shooting I suppose.
09-27-2010, 04:28 AM   #48
When i did a test at PK the K5 i managed to get 4 RAW before slowing down.
09-27-2010, 04:38 AM   #49
Ash
Ash's Avatar
How much improvement could we expect from firmware updates if the buffer's capacity is what it is?
09-27-2010, 05:40 AM   #50
JohnBee's Avatar
I have my doubts on how much that could do toward the issue. But then again, I am far from an expert on such things.
However... there is also the possibility of improving the no. of total frames with the new SDxC cards. Assuming the cards could provide enough bandwidth to make a difference.
09-27-2010, 06:54 AM   #51
alexeyga's Avatar
Hopefully the production model will get improved... the fundamental problem, however, lays no only in buffer's size, but also in the processing engine... There's a reason why 7D comes with 2 processors.... there's a reason why D7K got a new one as well... But despite increase in FPS and resolution Pentax is still trying to push all that sh@t load of data with the old and trusty Prime II... when Ideally, they should either use two of them or the Prime III or IV....
10-18-2010, 09:04 AM   #52
So what is the verdict?
Do the K-5 have an 8 or 15 raw pictures deep buffer?
10-19-2010, 10:13 AM   #53
calm down
Personally, i dont care about shooting 900 RAW photos in a row, especially considering how good the k5 jpegs look. then you have to look through them all. i dont really buy into the machine gun approach anyway. but why dont you knock off the histrionics and ask one of the several people on this forum who now own k5s with final firmware to run a few buffer tests? then you will know for sure and wont have to wrangle with the confusing specs
10-19-2010, 10:15 AM   #54
dgaies's Avatar
QuoteOriginally posted by Gimbal Quote
It depends on the ISO level.
At low levels (100-800) you should get about 8. Around ISO 6400 it drops to 4 pictures.
10-19-2010, 10:52 AM   #55
Yes I have seen it now, approximately one second of continuous shooting. Or "continuous" might not be the right word here, it's more like a really-short-burst mode.
buffer, camera, dslr, eight, iso, k-5, k-5 ii, k-5 iis, k-7, k5, limit, pentax k-5
The case of the K5 buffer size ... can someone explain? jpzk Pentax DSLR Discussion 25 09-22-2010 09:10 AM
K7 Buffer Issue? samholton Pentax DSLR Discussion 4 01-08-2010 07:19 AM
K-7 40 jpeg buffer enough? Pentaxor Pentax DSLR Discussion 5 06-28-2009 01:28 PM
K100D Super Buffer? res3567 Pentax DSLR Discussion 7 05-10-2009 05:13 AM
Buffer Write Speed of the K10d ruemiser Pentax DSLR Discussion 5 12-30-2007 09:41 AM
All times are GMT -7. The time now is 08:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
