10-16-2010, 01:03 AM   #1
JohnBee's Avatar
K-5 ISO6400 vs ISO80 - Advanced NR Study...
I won't bore you all with the details, but someone mentioned we could do better.
And since this is a new system and there's always room for improvements... why not go for the gold!
Having said that, here are a few ISO6400 sample of what I like to call the 'advanced noise management method'. Which is nothing more than applying NR selectively throughout a scene rather than globally.
Tools used: Topaz Denoise, Focalblade, and PS masking
Time to render: 4 to 7 minutes.(Depending on methods)
Original mention:
At the top of the mug there are lots of marks on the ISO80. they are not present on the 6400.
Solution: Advance Noise Management
Final Render:
ISO6400, w/ANR:
GLOBAL NR, Method: ISO6400, NR
Advanced NR Method: ISO6400, ANR
ORIGINAL: ISO80
...full size image cab be downloaded here.
It could still use a little tweaking(white and dark peak control(sharpening mask), however, the fact the ANR version has been overshot(detail wise) is a very positive sign toward perfection.
The question now is... if we can get this out of a JPG... what can we expect from RAW files?
And now... I think the relative ease this sensitivity is making it to achieve such results is a sign that we should now be turning our attention toward the ISO12800 output end of things..
~the end
10-16-2010, 01:22 AM   #2
That's ISO 6400 ?
There is so much detail texture in the condensate on the mug, even after NR...
I need a beer after this
10-16-2010, 02:15 AM   #3
This test proves nothing....
latest "look how it good it is"tests indicate that you will need nosehair pics to prove it
10-16-2010, 02:18 AM   #4
Ash
Ash's Avatar
Good work with this John. Something to further masticate over... (word choice intended )
There's more and more brought out in these high ISO shots it's hard to critique them... and harder to resist the K-5 bug. Thanks for the work in sharing these results.
10-16-2010, 02:30 AM   #5
Steelski's Avatar
I guess that was me John. Well done. I know the improvement is marginal, but its there. For critical high ISO work, I would expect images to take around 5-10 minutes to get perfect noise wise.
Yeah, I think we all want to see some RAW conversions now.
10-16-2010, 02:43 AM   #6
JohnBee's Avatar
QuoteOriginally posted by Steelski Quote
Yea, I'm actually quite glad you brought it up.
I was going to settle on the initial results, but you're comment justified investigating further into the NR process which I think was well worth the efforts.
I also think its very at this level(with this particular file), we can almost say, ISO6400 is worthy of professional use. Which is rather huge if we factor in sports, bird watching, and the various events that would lean heavily in low light conditions. Still... were haven't seen enough of the system at work to conclude it's a solid win just yet. And so there's much more to see and consider in terms of performance to look into yet.
PS. I am really hoping someone will post DNG/RAW files similar to these for us to look at. I know it's alot to ask for, but it would mean a great deal for those of us waiting in the side lines on what to expect from this new system in the field.
10-16-2010, 02:46 AM   #7
Col
QuoteOriginally posted by janneman Quote
Misread that The new Pentax Noisehair test. Where has this facial hair fixation come from?
10-16-2010, 09:34 AM   #8
Pentaxor's Avatar
Thanks again JB. your post-processing skills and methodology are excellent. hope that you can touch us personally.
10-16-2010, 10:04 AM   #9
Pentaxor's Avatar
btw, what's the difference between Global NR and Advance NR?
10-16-2010, 10:16 AM   #10
Pentaxor's Avatar
btw, JB cant wait for the RAW samples. it will also be nice to see RAW comparisons between K-5, K20D, K-7, Kx samples from ISO 6400 - 12,800 (25,600).
anyway, from your own personal observations, how does the ISO 6400 jpegs compared to your K20D/k-x RAW converted and PP NR results?
IMO, the K-5's ISO 6400 is as clean as the D700. although the details and sharpness is on the D700 is superior. however, I would take this with a grain of salt since these are post-processed jpeg and not RAW.
10-16-2010, 12:50 PM   #11
johnmflores's Avatar
Thanks for doing and stoking the flames of K-5 desire even higher!
10-17-2010, 07:22 PM   #12
Eruditass's Avatar
QuoteOriginally posted by Pentaxor Quote
He's just making 2 layers and selectively using a mask.
10-17-2010, 08:27 PM   #13
Pentaxor's Avatar
QuoteOriginally posted by Eruditass Quote
thanks.
camera, dslr, iso6400, k-5, k-5 ii, k-5 iis, k5, management, method, noise, nr, pentax k-5, sign
K-5, ISO80 vs ISO6400 Early Case Study(JPG)... JohnBee Pentax K-5 & K-5 II 67 10-18-2010 06:53 PM
K-7 ISO3200 Advanced NR Case Study JohnBee Digital Processing, Software, and Printing 3 06-18-2010 01:02 AM
K20D ISO6400 Image set JohnBee Pentax DSLR Discussion 21 05-16-2010 12:24 PM
Lets try some ISO6400 with LR3 Beta... JohnBee Pentax DSLR Discussion 26 04-20-2010 05:17 PM
K-x iso6400 black cat planedriver Pentax DSLR Discussion 4 12-15-2009 08:28 AM
All times are GMT -7. The time now is 12:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
