10-16-2010, 12:40 PM   #1
dgaies's Avatar
Two K5 quirks I noticed, any other K5 owners notice these?
So I've been playing around with my K5 this afternoon and noticed two strange things and I'm not sure if they are specific to my K5 or all K5s.
The first thing is that during playback, when you are viewing a vertical image and turn the body 90 degrees, the image doesn't flip automatically. On the K7 when you view a image taken in the portrait orientation and turn the body vertical, the image rotates too such that it fills up the screen. For some reason that's not happening on my K5.
The second strange thing I noticed is that when you half-press the shutter to activate the SR system, if you release the shutter without taking a picture, the SR-icon remains lit up for a while. On my K7, it would immediately go away if you release the half-press of the shutter. I didn't know if this meant the SR is still active for some time after (which might be a good thing) or if there was an issue with the camera body itself (which would be a bad thing).
Anyway, if anyone else who has a K5 wouldn't mind checking to see if this is happening on their K5 as well, I would appreciate it.
Thanks.
10-16-2010, 12:54 PM   #2
QuoteOriginally posted by dgaies Quote
That's a feature.
10-16-2010, 12:54 PM   #3
This seems to be a feature, not a bug. Was already posted in some preview.
10-16-2010, 12:55 PM   #4
dgaies's Avatar
QuoteOriginally posted by Edvinas Quote
That's a feature.
QuoteOriginally posted by Xatnep_CJ Quote
Makes sense, and I was hoping it was a feature as it would be nice to be able to activate the SR so it is ready without keeping your finger on the shutter button.
Thanks for letting me know
10-16-2010, 01:05 PM   #5
imtheguy's Avatar
Thanks.
Mine rotates (as does the info screen). Did you change the Menu default for remembering rotation info? I did.
10-16-2010, 01:13 PM   #6
dgaies's Avatar
QuoteOriginally posted by imtheguy Quote
If you mean the "Auto Image Rotation" check box on the blue "Playback-1" menu, then I do have it checked. Also, Custom Menu #23 - "Savings Rotations Info" is set to "On". Is that what you meant or is there something else I need to check.
FWIW, my info screen rotates properly and the images are recorded with the proper orientation, so I assume the orientation sensor is working fine. It's just when reviewing images I can't get the images to rotate by rotating the camera body itself.
10-16-2010, 01:26 PM   #7
imtheguy's Avatar
Uh...yes,thats it. I did not look before typing the name.
When I put a check in the box for "Auto Image Rotation" it rotates the displayed pics taken in portrait. I just un-checked it and the portrait shots did not rotate on the LCD during review while the camera is held in normal landscape mode.
EDIT - When you shoot in portrait, does checking/unchecking the box do ANYTHING when you display?
10-16-2010, 01:36 PM   #8
dgaies's Avatar
Unchecking the box makes it so the image take up the whole screen, regardless of camera orientation. Checking the box makes it so that a portrait image will have the black bars on the sides if I am holding the camera in landscape mode during playback. The issue is that at this point I should be able to rotate the body 90 degrees and the picture should rotate as well to fill up the screen (like the info screen does). But for some reason, that's not happening on my K5 properly.
10-16-2010, 02:05 PM   #9
imtheguy's Avatar
I think the way it works is the way it was intended. Yes, a dynamic mode like the screen would be cool though. I have not read anything that says it SHOULD work like that though. But....the User Guide is 370 pages and I am only 150 into it.
10-16-2010, 06:48 PM   #10
dgaies's Avatar
It might be working as intended
I've haven't found anything in the User Guide that suggests anything is actually wrong. I just assumed that because my K7 automatically rotates pictures dynamically during playback (based on the body orientation during playback) that the K5 would have that feature as well. I found it quite useful on the K7. No big deal though, it just seemed odd that it didn't work on the K5 the same way (or at least as an option).
10-16-2010, 10:48 PM   #11
In K-7 manual they explicitly write about this feature in Playback Functions/Rotating Images section of the manual (page225):
Images with rotation information are displayed according to the orientation of the camera.
10-16-2010, 11:06 PM   #12
creampuff's Avatar
Probably a firmware update will address some of the small niggling issues. Don't lose sleep over it.
10-17-2010, 05:29 AM   #13
dgaies's Avatar
Just to be clear, the K5 does display the proper orientation during playback. If you took a vertical shot with the K5, when you go to play it back the image will be displayed vertically with black bars on the side (assuming you checked off that option in the menu). What (my) K5 doesn't seem to do (that the K7 does) is rotate the picture to fill up the whole screen when you physically rotate the body during playback.
QuoteOriginally posted by creampuff Quote
No worries, I slept fine last night
I was just trying to figure out if there was something wrong with my specific copy of the K5 as opposed to a small bug (or maybe an intentionally omitted feature) from all K5s.
10-17-2010, 06:56 AM   #14
Personally, I like the Auto-Rotate feature, but I find Dynamic Auto-Rotate on the K-7 irritating.....that's just me though...no big deal either way...
10-18-2010, 12:15 AM   #15
Yep, that's exactly what I am talking about. And in K-7 manual they write about it. I wonder wether they have the same wording in K-5 manual?
body, camera, dslr, image, k-5, k-5 ii, k-5 iis, k5, pentax k-5, release, shutter, sr
Quirks on K-7 NOT FOUND in K20D (Confused with my new K-7!) PentaxForums-User Pentax DSLR Discussion 16 05-16-2010 10:23 AM
Suggestion for Sigma 24-70 owners (or potential owners) joeyc Pentax SLR Lens Discussion 4 08-07-2009 03:12 AM
Noticing photography quirks in movies Andi Lo General Talk 18 08-02-2009 07:26 PM
K20D Quirks bentax Pentax DSLR Discussion 10 09-27-2008 05:51 AM
K100D AF quirks with Tamron 90! joele Pentax DSLR Discussion 1 09-14-2006 10:25 PM
All times are GMT -7. The time now is 12:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
