10-17-2010, 06:37 PM   #61
jpzk's Avatar
A little while back, someone posted a series of pics of an uncoming car. This was, I believe, taken with a K7.
Pretty much all of the images were in focus.
Anyway, something like this could be done with the K5?
Just make sure you are not becoming the target!
10-17-2010, 06:44 PM   #62
falconeye's Avatar
QuoteOriginally posted by dotchoucou Quote
The best would be to try the camera at an indoor shooting range place.
The system of the target coming back towards the shooter to check the accuracy would be perfect (constant speed) and the light should always be the same.
If one can put the camera on tripod with an angle it could be a nice testing setup I guess.
That's an interesting proposition. Thanxs.
10-17-2010, 07:07 PM   #63
falconeye's Avatar
Just saw a short review of a D300 user trying a D7000 . He tried to get pictures like this one.
He says that he succeeded with his D3 (cf. above picture) but failed with the D7000 while trying with both. He thinks the D7000 AF is closer to D90 than D300.
I wonder if that would be found by a "LS3" test. And it is one user's opinion only, of course.
Nevertheless, a standard BIF situation (prey at a given location) could be a better way to compare AF systems than the simplified LS3 tests.
10-17-2010, 11:37 PM   #64
QuoteOriginally posted by jpzk Quote
That's what I'm talking about! This will be far more better AF-C test than people/children running (thanks for these tests anyway). Just make sure to shot wide open and with focal length at least 200mm :-)
10-18-2010, 12:01 AM   #65
QuoteOriginally posted by jrforman Quote
.......... What I can say is that there isn't a frame missing. I was panning with the camera, keeping the person centered, and it seemed to skip over the tree - perhaps couldn't get a focus until I was beyond the tree? ...........
I would be the first to say that we need better testing methods. And I would like to try with the five point method you mentioned. And with my dog at home.
The Publicity blurb on SAFOX IX indicated it has predictive tracking AF (how good we will have to see) , and this may well be a sign of the predictive AF in action.
You were tracking the biker in action through several frames. In one frame, he disappeared behind the tree. The AF system "expected" the biker to be still there, though there's suddenly a tree there.
It did not start hunting all over, lock on the tree, and lose track of the biker, which previous Pentax bodies would have done. I reacquired the biker in the next frame.
The Nikon system reacts much faster , no doubt still better than Pentax, but perhaps we've got something very interesting in the K-5's brain....something we haven't had with previous Pentax cameras.
10-18-2010, 12:15 AM   #66
No tree shooting?? Bummer
QuoteOriginally posted by kittykat46 Quote
So, what that means is that whn I am tracking a biker and I suddnely want to take a picture of a beautifull tree, I can't???? Must cancel pre-order...
10-18-2010, 12:47 AM   #67
QuoteOriginally posted by janneman Quote
Hihihi a very good, fast predictive AF will do both...by quickly reacquiring your earlier tracking object.
I had the experience last year with Formula 1 , using a borrowed D90.
Tracking a race car down the track. Guy walks right in front of my lens - one spoiled shot. The camera immediately goes back to tracking the race car, next frame still in focus...its almost uncanny.
Sorry to sound like a Nikon fan, I'm not one, but they have something very good there.
I'll be very happy if Pentax catches up part of the way. I still prefer Pentax for a whole lot of other reasons.
10-18-2010, 12:53 AM   #68
who can test how K-5 takes such photos - fast paning
My K-7 examples:
10-18-2010, 01:01 AM   #69
All my Pentax cameras do that. And even my "slow" *istDS was able to track formula1 cars. Picture below is taken with my *istDS and FA*400/5,6. It is only cropped a small amount (to 90%, I think) which should give an indication of how close the cars was. And the speed is probably well over 200km/h.
10-18-2010, 01:55 AM   #70
When shooting a race you are far from the subject what IMHO requires less effort from AF (I think shorter and slower focus ring turns?), try to catch a fast moving car that goes at you and passes you.
My hobby almost from the moment of birth is rallying. I think it's the more demanding than racing. Unfortunately it's hard to spot someone who is using pentax for that. I'm trying to shoot with I think not bad results.
Vaikis_, your drifting shots (beside beeing overxposed) look like from a poor lens, big crops or with missed focus And panning is much easier for AF as the car is usually not heading directly at you. Mayby the last shot was a bigger problem for AF.
10-18-2010, 03:07 AM   #71
QuoteOriginally posted by Raven Quote
it was very sunny day and lenses DA 55-300 Not the best Where you see missed focus ?
10-18-2010, 03:48 AM   #72
Almost on all of them, but maybe it's your hand shaking or 300mm wide open? I also use 55-300 and I get much sharper pictures and after some sharpening in PS they look very good.
10-18-2010, 04:20 AM   #73
you know what is paning ? Still objects I can get very sharp also
10-18-2010, 04:47 AM   #74
Haha, I think I know pretty well what panning means
10-18-2010, 06:47 AM   #75
falconeye's Avatar
Panning anybody? What about panning in BIF with a K20D
K20D with Sigma 18-250 @ 200mm, cropped to 600mm (35mm equivalent).
K20D with FA*300/4.5, cropped to 2200mm (35mm equivalent).
This buzzard lives in the wild and I can see it hunting from time to time while working Obviously, longer than 300mm and TCs are mandatory in BIF for untamed birds and the tests of AF with TC mounted to the lens make a certain amount of sense then ...
Unfortunately, TC with Pentax AF is a problem because the TC doesn't multiply focal length and more importantly, the lens code K_value to the body. This makes Pentax AF hunt with a TC.
af, camera, dslr, hype, iso, k-5, k-5 ii, k-5 iis, k5, k5 af, pentax k-5, performances, tests
DA* 60-250mm tests.. Mystic Pentax SLR Lens Discussion 3 04-27-2009 01:11 PM
Resolution Tests YarPcola Pentax SLR Lens Discussion 16 05-07-2008 05:09 PM
Tamron 17-50 f2.8 tests AlexL Pentax SLR Lens Discussion 15 04-14-2008 06:33 AM
More tests from 50-135 thomasjmpark Post Your Photos! 11 02-07-2008 09:30 PM
New images (I think) and tests. jeffkrol Pentax News and Rumors 26 02-06-2008 07:19 PM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
