10-17-2010, 12:53 PM   #31
raz
MAC can you investigate why the K-5 image look more exposed than the K-7 ? Even the wall behind looks brighter ? My guess is the sensors have different sensibilities , I mean iso 200 is not iso 200 for both sensors, even if the display sais so ?
10-17-2010, 01:25 PM - 3 Likes   #32
MAC
QuoteOriginally posted by raz Quote
I just did a quick n' dirty comparison.
With the camera in manual at ISO 100, 5 sec., f8 with all camera settings absolutely identical the k-7 image was noticeably darker, as already observed with most of the shots in this thread. The histograms back up what we're observing. I adjusted the k-7 ISO up 1/3 stop at a time until they appeared to match, and at ISO 160 the histograms are nearly identical.
I'm afraid I've run out of time to do any further testing right now.
Hopefully one of the other K-5 owners here can help answer this.
10-17-2010, 02:02 PM   #33
raz
Thank you MAC for the answer, your work and pictures placed here are appreciated.
10-17-2010, 02:28 PM   #34
QuoteOriginally posted by MAC Quote
I just did a quick n' dirty comparison..
Hm, my K-7 ISO 3200 does not look as good as yours...
10-17-2010, 02:47 PM   #35
Ex Finn.'s Avatar
This is good stuff, thank you for your effort MAC.
10-17-2010, 05:25 PM   #36
From my observation I'd say the difference is > 1 Stop and < 2.
But did anyone notice the lose of Dynamic Range in K7 high ISO smaples? There's a MASSIVE lose of DR in the shadow areas after 1600, after 3200 there is no hope/ it's not even funny.
That's what made the K7 high ISO shots looked more contrasty - the shades in the shadorw area are all just clipped.
That is shocking!
I think I'm going to upgrade to K5 when it arrives in Australia...
Thank you for your time and effor OP! Really appreciate it.
10-17-2010, 05:47 PM   #37
audiobomber's Avatar
QuoteOriginally posted by Katsura Quote
True, but this is exacerbated by the K-7's darker exposure in the samples.
10-17-2010, 06:58 PM   #38
Mmm, I'm not so sure the K7's exposure is that that off/ darker.
Looking at the pictures showing the whole scene instead of the crops, and compare the light areas between the K5 and K7, then compare the shaded areas. I'd say the expore is very close/ certainly within 1 stop? The K-7 maybe underexpose by a tiny little bit. (due to variation between real ISO and indicated ISO???) Maybe we need to feed these into PS and observe the histogram for accurate measures.
But the difference certainly should not make for such a HUGH DR clipping in the shadow area.
Or maybe I'm reading this wrong? If so pls enlighten me.
10-17-2010, 07:03 PM   #39
Hi what's the band/ corrupt data looking strip on the left and right hand side of K-5's pictures?
10-17-2010, 09:33 PM   #40
MAC
Those appeared when I opened up the files in PSP Pro X3. It didn't happen to the K-7 files, so if I had to guess I'd say it's a result of editing the files with a program that hasn't been updated to be compatible with the new camera. As far as I could tell, nothing within the image was changed and it just added a 5 pixel wide strip to the left side, and a 15 pixel wide strip to the right. I was able to successfully crop them out of most of the K-5 samples, must've just missed that one.
10-17-2010, 10:42 PM   #41
ogl
ogl's Avatar
To compare noise, we should use UFRAW or DCRAW without NR in settings and PEF files.
And then compare JPEG results from DCRAW converter. It shows us the real noise of sensors.
Any other comparision is not honest.
10-17-2010, 10:46 PM   #42
ogl
ogl's Avatar
Yes. I did everything i could the second time around to avoid NR
can you simply to upload your PEF files to free uploading server?
as for me, K-7 looks sharper, by the way.
10-18-2010, 04:24 AM   #43
The K7 actually does better at high iso than most people think. The problem is that if you under expose, even a little bit, and have to bring the exposure up, the photos tend to suffer severely. There is just no head room at all. I would hope that the K5 would give a little bit more leeway for post processing.
The other thing that is mentioned is that the K5 seems to keep dynamic range into high iso shots way better than the K7 does. By the time you get to iso 6400, with the K7, you are pretty much better turning them into black and white photos.
By the way, Ogl, I thought you didn't like the K7. Why are you running down the K5 in comparison with it (particularly since you don't own either camera)?
10-18-2010, 04:59 AM   #44
I also stated that the K-7 low ISO photos are sharper. That's not running the K-5 down, it is a personal observation that IMO everyone here should be able to see. The fact that few have commented on it is disappointing. It's clear that high ISO on the K-5 is better by +/- 2 stops. From these samples, it is not clear that low ISO is as good.
10-18-2010, 05:53 AM   #45
QuoteOriginally posted by audiobomber Quote
I don't think much at all is clear from these low iso samples. I'd rather wait to see some high dynamic range scenes to see what the K5 can do. I am really pretty satisfied with my K7 anyway. However, even at low iso, the K7 has limited ability to pull up the shadows.
There are some people who get too excited about new equipment and others who find fault with everything new. Probably the truth lies somewhere between the two. I'm not getting a K5 right away anyway, but it does look pretty good to me.
camera, comparison, dslr, k-5, k-5 ii, k-5 iis, k-7, k5, nr, pentax, pentax k-5
K7 high iso noise comparison cyy47 Pentax DSLR Discussion 24 08-02-2010 02:19 AM
K7 vs d3. Comparison!!! vitalsax Pentax DSLR Discussion 26 05-30-2009 06:04 AM
cs3 noise filter vs. noise ninja vs. ??? reknelb Pentax DSLR Discussion 0 03-04-2008 04:55 PM
K20D Noise Comparison against A700, 40D, D300, D3 Tobogi Pentax News and Rumors 25 02-09-2008 08:19 AM
image comparison using 'neat image' noise reduction programme. distorted_vision Post Your Photos! 18 12-28-2007 04:44 AM
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
