10-18-2010, 10:08 PM   #16
what SD cards you use for measurments ? Please use LexarŽ Professional 133x - it's very fast card
10-18-2010, 11:17 PM   #17
ogl
ogl's Avatar
QuoteOriginally posted by dgaies Quote
Just tried it and I got:
9 @ ISO 200
9 @ ISO 1600
8 @ ISO 3200
4 @ ISO 6400
4 @ ISO 12800
4 @ ISO 51200
K-5 has NR in RAW from ISO above 1600.
No NR AT ALL at ISO80-1600.
10-18-2010, 11:21 PM   #18
ogl
ogl's Avatar
7 FPS high, 2 FPS low.
What about at normal ISO? Will we get 40 JPGS, or just 22?
Close to 20 JPEG (depends on SD card). My friend've tried.
10-18-2010, 11:25 PM   #19
imtheguy's Avatar
I ran both jpg and raw from iso 200 to 12800. I get 27 jpg at full speed before it slows, up to iso6400 where it drops off to 7 jpg bursts...RAW+ drops from 7 to 3 at iso6400. I don't like it especially but truth be told I don't have much need for long bursts at that high an iso....yet.
I use Sandisk 8gb Extreme III 30MB/Sec.
10-18-2010, 11:26 PM   #20
Boosting EV in post-processing?
I read on some preview somewhere that the highest native ISO was 6400 and after that it was all done by boosting EV in post-processing. Is this true?
10-18-2010, 11:28 PM   #21
sorry about the double post, but also:
Can anyone tell me whether there is a difference to burst rate and buffering @ various ISO with LOWER resolution JPG's?
Thanks.
10-19-2010, 12:54 AM   #22
Why does Pentax always do this?
Why do they handicap their otherwise excellent cameras?
I remember that they already had one entry level camera whith extremely small buffer. Every reviewer was pointing to this.
Now K-5. It's almost useless for action. Burst for one second only. And only 4 frames in higher ISOs. Give me a break. Why did they bother with those high frame rates and new AF modes at all. They are not going to be useful with this small crippled buffer.
Now we again have the situation where Pentax entry level camera outperforms their flagship model...
10-19-2010, 12:58 AM   #23
So at iso 6400 and higher we will have to state the burst speed in frames per half-second?
10-19-2010, 01:44 AM   #24
ogl
ogl's Avatar
QuoteOriginally posted by imtheguy Quote
My friend used SD Transcend. 2 GB.
10-19-2010, 01:58 AM   #25
QuoteOriginally posted by ogl Quote
it's slow card
Maybe Pentax is planing to release new Firmware with SDXC card support, then unload from camera buffer should be faster.
10-19-2010, 02:12 AM   #26
i think this is not card, but processing related.
i also believe that they can fix it to match low ISO buffer size.
this slowdown could happen due NR done for RAW in which case they could just give an option to turn it off.
or it could be from jpeg generation with advanced NR which is usually included in RAW file. they could then just skip NR for "preview" jpegs attached to RAW
10-19-2010, 02:31 AM   #27
QuoteOriginally posted by 0144 Quote
slowdown is due big files which needs to be processed. Also there is no need to use 14 bit for shots which are above ISO 400, because it's increase file size also. Extra least significant bits contain nothing but random noise Pentax could use 14 bits in iso 80-400 and for other shots just keep 12 bit or just make settings in new firmware release, that user could choose.
10-19-2010, 03:00 AM   #28
Arpe's Avatar
QuoteOriginally posted by Edvinas Quote
Indeed, that's just what I'm thinking. Though I don't use a burst of more than about 4 or 5 very often, I have found it handy in the past for sport where a player suddenly bursts a tackle and carries on running much further, so I've already taken about 4 or 5, then want to follow with a few more frames. It just seems almost so petty to leave it so low.
10-19-2010, 03:23 AM   #29
For me, this is a crunch point.. I'm hoping SDXC support will help this out.
10-19-2010, 03:27 AM   #30
Steelski's Avatar
Lets look at this a bit more logically, If the issue arrives at 6400 then its possible to just shoot 3200 and push process later. It would not be recommended for 12800 and above, but 3200 to 6400 should not be much of a problem.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
K7 Buffer Issue? samholton Pentax DSLR Discussion 4 01-08-2010 07:19 AM
K-7 40 jpeg buffer enough? Pentaxor Pentax DSLR Discussion 5 06-28-2009 01:28 PM
K100D Super Buffer? res3567 Pentax DSLR Discussion 7 05-10-2009 05:13 AM
Buffer Write Speed of the K10d ruemiser Pentax DSLR Discussion 5 12-30-2007 09:41 AM
Loving the buffer size - K10D!! photo_mom Pentax DSLR Discussion 27 12-10-2006 06:32 PM
All times are GMT -7. The time now is 08:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
