Originally posted by Rondec Have you ever dropped a camera? The issues you have to worry about are really not the frame, they are the internal workings and electronics of the camera. None of that stuff will be cheap to fix with Pentax or Nikon and neither company will cover the repair once they figure out that you dropped it. The question is what about normal wear and tear, dust, humidity, etc that you experience on the trail.
Currently, as far as I can tell, Pentax offers the DA 18-55 WR, 50-200 WR, DA 18-135 WR, DA * 16-50, DA * 50-135, DA * 200, DA * 300, D FA WR 100, and DA *55 lenses that are weather sealed. They range significantly in price of course, from the 18-55 which sells used for 115 dollars to the top end lenses that sell for 1300 dollars.
Nikon's cheapest normal zoom with sealing is the 17-55 which sells for about 1300 dollars and is a very nice lens, but also lacks IS for that price. Of course, according to Nikon, you don't need IS for shorter lenses, so you'll be OK.
Exactly! I'm with you on this one.
In the touch wood situation that the camera drops on a tour or in the middle of nowhere. I'd be more concerned about it still working and giving me shots and not giving me a double whammy of dropped camera and no shots for holiday/expedition. Of course I'd still swear
Originally posted by jremick A
At this point, my plan is to get the K-5 body in 3-4 weeks and just stick with my K-X 18-55mm kit lens until the following month. Then I'll probably pick up the 18-55 WR and 50-200mm WR unless the 18-135 WR actually turns out being worth the hefty price. Then the following month I'll look at getting one or two lenses like the 50mm 1.4 or 1.7, etc.
One thing I'm not looking forward to is the fact that the K-5 will need the base grip attachment so I can use AAs with it. I loved that the K-X used AAs and I bought a bunch of eneloops so I'd like to be able to keep using those. $200 for the base grip is kinda *ouch though, lol.
Good on ya!
Seems like you've already made up your mind.
I'd just like to add the following pros to a K5.
1. On camera SR w/o more expensive, cumbersome and heavier lenses. Think about how much more space and weight you need to lug around with a Nikon system.
2. Some budget WR lenses for outdoor use (not just expensive 'pro' level stuff)
3. Excellent small and light primes if you want to go this route.
4. On camera auto aligned HDR for more possibilities
5. ISO80 for landscapes, low/dim light work with tripod and as a work around the max flash sync speed of 1/180.
6. Very much well (enough) documented ISO performance from all the pixel peeping; RAW samples; 100% crops; analysis that has been shown so far for the K5.
7. AF performance that is very much improved over the old Pentax bodies. (I dare say its night and day now)
8. 5 exposure, extended bracketing
