10-21-2010, 07:30 AM   #1
K-5 Select Af point in live view
I saw a video before the k5 was launched that showed the live view focus point being moved around the screen using the 4 way controller. At the time I thought it was a great idea for macro tripod shots. I have read the manual and cant find any way to do this. All that happens when I press the controller is the function for that button pops up.
Have tried all the AF modes, no joy. Any ideas K5 owners?
Terry
10-21-2010, 07:57 AM   #2
RBellavance's Avatar
It's the same as when you're not in LiveView, i.e. press "Ok" before the 4-way pad. You must be in "SEL" mode, of course.
There is also a custom option that reverses the function of the "Ok" button, i.e. the 4-way pad defaults to moving the AF point, and you must press "Ok" first to access the function of each button.
10-21-2010, 08:08 AM   #3
Thanks
QuoteOriginally posted by RBellavance Quote
I found it by trial and error! Strange for me it works in all AF modes. Very useful for macro work. Thanks for the response.
Also you can use the info button almost the same way though not as accurate.
10-21-2010, 08:22 AM   #4
scole's Avatar
Where is the option to revert the OK button's function?? Coming from a K10d, this has been KILLING me!
Thanks!
10-21-2010, 09:05 AM   #5
I don't own a K-5 (yet ), but on a K-7 it's Custom setting 36 "Operate at AF point SEL". With this, "Ok" on the K-7/K-5 becomes more or less what "Fn" was on the K10D.
10-21-2010, 11:38 AM   #6
dgaies's Avatar
QuoteOriginally posted by scole Quote
Thanks!
If I understand the question right, I think you need to hold down the "OK" button. This will toggle between the focus points and the WB/flash/drive functions. A single push centers the focus point.
af, camera, controller, dslr, k-5, k-5 ii, k-5 iis, k5, live, pentax k-5, view
How do you use live view? photog Pentax DSLR Discussion 29 03-03-2012 05:40 AM
Live view: K-x, K-r WMBP Pentax DSLR Discussion 8 09-18-2010 04:51 PM
AF in Live View with K-7 Kameraten Pentax DSLR Discussion 11 08-12-2010 09:15 PM
K-7 Live view? redpigeons Pentax DSLR Discussion 9 04-24-2010 06:33 AM
Live View - Not getting use to it Rudi Pentax DSLR Discussion 27 11-23-2008 06:56 PM
All times are GMT -7. The time now is 04:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
