10-22-2010, 09:30 AM   #1
jpzk's Avatar
K5 programmable RAW/Fx button ... who is using it yet?
This is a three part thread:
1. Who is using this button for programming a function other than the RAW option, and what do you use it for?
2. Is this also a button where you can assign a "User" function?
3. USER mode ... anyone tried the full capabilities of that yet?
.... trying to find a user manual for the K5 here ... available somewhere?
Thanks folks!
JP
10-22-2010, 10:20 AM   #2
I use mine for bracketing.
I have set up 2 user modes, one for fast action stuff and one for macro. seems to work well. Only thing I found annoying is that there seems to be no way to switch between setups unless you turn the main selector knob off user then back again.
10-22-2010, 10:36 AM   #3
if you wanna switch user modes faster, just hit menu (while in user mode), and then the first option will be user mode change...
10-22-2010, 10:40 AM   #4
QuoteOriginally posted by benisona Quote
Thanks. I guess I have to read the manual closer
10-22-2010, 10:43 AM   #5
Thanks. I guess I have to read the manual closer Oops just tried it and it just takes me into the menu. Doh Ok you have to select the user mode then scroll to the one you want, pity the names you give them don't show up in the menu.
10-22-2010, 12:00 PM   #6
QuoteOriginally posted by telfish Quote
One more for the FW update!
10-22-2010, 12:44 PM   #7
jpzk's Avatar
Yeah, that would make a lot of sense because it is somewhat tedious to set the AEB with the K7 because you have to go "in" and do it there. With this button ... easy enough!
Thanks,
JP
button, camera, dslr, function, k-5, k-5 ii, k-5 iis, k5, pentax k-5, raw/fx button, user
Programmable RAW button breischl Pentax DSLR Discussion 28 09-28-2010 04:54 PM
Configuring the K20D's RAW button? jeremy_c Pentax DSLR Discussion 10 12-03-2008 08:27 AM
K10D RAW button PollitowuzHere Pentax DSLR Discussion 18 06-11-2008 07:27 PM
RAW button Selections Steve823 Pentax DSLR Discussion 6 04-30-2008 11:26 PM
RAW Button Programming Matt Photographic Technique 8 03-02-2008 06:42 AM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
