11-01-2010, 01:14 PM   #46
Feudal1's Avatar
Receiving my K5 tomorrow - this thread has me a little worried, as I make use of flash a fair bit in my photography. I've had no issues like this with other camera manufacturers, so I'm hoping this isn't a big issue, and if there is a problem, that it's corrected relatively quickly.
11-01-2010, 02:09 PM   #47
QuoteOriginally posted by Feudal1 Quote
Good luck to all of you and keep us posted.
NaCl(no! not my baby! my baby is perfect!!!!)H2O
11-01-2010, 04:31 PM   #48
I'm waiting for the upcoming firmware update to see if it fixes this. I'm getting consistent enough results now that I'm thinking this is more likely a software bug rather than a hardware problem.
11-01-2010, 05:54 PM   #49
filorp's Avatar
QuoteOriginally posted by Cannikin Quote
yeah, it needs just -3 compensation on the flash isnt it?
11-02-2010, 05:46 AM   #50
Naim Khan's Avatar
I have posted this in another thread but am mentioning it here as well:
I have just come off the phone with Pentax. They say they have escalated the problem and have referred it to Pentax Europe. Presumably they are taking the matter seriously and are trying to sort it out ASAP.
Cheers.
11-09-2010, 02:02 PM   #51
jpzk's Avatar
QuoteOriginally posted by Naim Khan Quote
Cheers.
Any further news from Pentax about the K5 flash problem yet, either here or on any other thread?
JP
11-09-2010, 02:06 PM   #52
Naim Khan's Avatar
QuoteOriginally posted by jpzk Quote
JP
I haven't heard anything from Pentax but plan to ring them on Thursday morning (only day I can get from work). I planned to update you all when I had heard anything from them. So watch this space.
Cheers
11-10-2010, 05:17 PM   #53
amoringello's Avatar
Not that it necessarily helps, but I was quite dismayed at reading these messages and had to try...
With AF540fgx attached, with ISO 100 and 5000, exposure is very nice and appears quite consistent both with the flash direct-on and angled. (I know it doesn't mean a thing with regards to Metz, but I thought someone mentioned having similar issues with the Pentax flash as well, so...)
I'd have to say the K5 is insanely more consistent with both color and exposure than I see with the K7.
The K7 is a turd with regards to flash exposure.
Hate to hear if some cameras are having this sort of inconsistency with behavior.
11-10-2010, 06:11 PM   #54
filorp's Avatar
QuoteOriginally posted by amoringello Quote
so we do know now: some k5s has a problem some doesn't, it means that the faulty one will need something more than just firmware upgrade unless there are some firmware differences between cameras....
amoringello can you check what firmware version your camera is? mine is 1.00.00.00
11-10-2010, 06:18 PM   #55
My firmware is reported as
PENTAX K-5
VER: 1.00
Via 'exiftool', reported as "1.00.00.00" for both DSP and CPU firmware versions.
11-10-2010, 06:23 PM   #56
filorp's Avatar
so it wont be just firmware upgrade....:-(((((
11-10-2010, 07:11 PM   #57
Since this thread is on flash use on the K5.
Is it me or has anyone noticed a slower AF with an external flash mounted?
Metz48 btw.
11-10-2010, 08:12 PM   #58
I have the AF540 as well and just tried to duplicate your results. I took shots at ISO100 and 5000 f8 and with the flash straight and at full upright. I had no change in exposure and no change between ISO's Pictures look really good for color. I had no compensation dialed into either the camera or the flash.
11-10-2010, 08:23 PM   #59
jpzk's Avatar
According to users of the K5/Pentax flash (AF540FGX) there seems to be no issue whatsoever with flash overexposure.
As someone mentioned earlier, this may be the case of a faulty K5 rather than the need for a firmware fix.
I wonder if people would be willing to rally up and test the K5 with a Pentax flash vs. other brands and post some results here on this thread?
When I tested the K5 at the store, of course there was no flash available ... that store is rather slim on different Pentax accessories. I have no choice for testing: this IS the only one which has Pentax products here in my small town.
So, I most likely won't be able to perform a K5/flash test on my own here.
In the end, Pentax has to know about this problem and if it is indeed a Pentax flaw rather than a flash issue (Metz), they'll have to fix it.
If it is, however, a Metz-only problem, there won't be any fixes from Pentax I would imagine.
JP
Edit: I had forgotten about this thread which mentions problems with a Pentax 360 flash and the K5.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/121716-new-k-5-issue-360fgz.html
so, maybe it is a K5 thing which would need further investigation.
11-10-2010, 08:51 PM   #60
Fl_Gulfer's Avatar
I have the same problem with my K-5 and Metz 58 works fine in Auto but overexposes in P-TTLHSS and P-TTL.
camera, dslr, everythings, flash, iv, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Faulty equipment or faulty photographer? (K-x) mamba909 Pentax DSLR Discussion 22 02-15-2010 12:16 PM
Faulty DA* 16-50mm ?? aleonx3 Pentax SLR Lens Discussion 12 05-11-2009 03:21 PM
Faulty SD card. Bramela Pentax Camera and Field Accessories 10 01-20-2009 12:39 PM
Is my k200d faulty or maybe not??? :( flamenco Pentax DSLR Discussion 9 01-16-2009 10:29 PM
Faulty K10D AE-L? Simon Pentax DSLR Discussion 2 03-03-2007 04:11 PM
All times are GMT -7. The time now is 04:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
