Originally posted by amoringello If you are close enough for the control flash to contribute to the exposure, and you turn that control flash to no longer contribute to the subject, the remote flash is going to try to compensate to make up for the lack of extra lighting.
Actually now I am beginning to question if there is a flash mounted on the camera whether or not it behaves differently in Master or Controller mode. In my test shots I can not find a difference in the lighting. It seems like it is always in Master mode. This isn't true if I use the pop up flash. Same for my K20D and K5. The custom option (#21) says "fires the
built-in flash as ...
In your example did you try setting the on camera flash to Master and Controller to see if you experience a difference? (nice examples by the way).
The K20D doesn't increase flash output of the remote wireless slave when I point the on camera flash to point toward it.
I usually use cybersyncs when I use flash anyway but would like to use P-TTL and wireless if it was reliable. Sigh, oh well. Everything can't be perfect.
