10-25-2010, 08:06 PM   #1
Wheatfield's Avatar
Note to Pentax, You Broke the 4 Way Switch on the K5
It's like Deja Vu all over again.
Again, Pentax didn't get it right with the 4 way controller. Set it to focus point selection and happily take pictures. Need to change a setting under the rocker switch?
Hold the OK button for a full second (the camera beeps) and then you can access the settings.
But the darned thing doesn't default back when you press the OK button to close out your settings.
You have to press the OK button to close, and then press it again (for a full second) to get back to focus point selection.
Granted, it's nowhere near as broken as it was with the K7, but hopefully they'll find a way to do a firmware adjust to fix it.
10-25-2010, 08:22 PM   #2
Ash
Community Manager
Ash's Avatar
Good suggestion Wheatfield. And the earlier it's mentioned to Pentax, the more likely something will be done about it.
10-25-2010, 08:46 PM   #3
I frequently switch between the two modes - AF point selection and 4-Way control selections.
Yes, a full second press on the OK button kind of gets in the way.
10-25-2010, 09:01 PM   #4
dgaies's Avatar
QuoteOriginally posted by kittykat46 Quote
Agreed. I'm not crazy about the full second press to toggle either.
10-25-2010, 09:04 PM   #5
Wheatfield's Avatar
It's probably closer to 3/4 second. It's still broken.
10-25-2010, 09:26 PM   #6
sounds yuk! don't like holding a button down for a lengthy (1 sec will seem like a long time when you're in a hurry!) time. Probably means you have to watch the screen too to see when it activates.
10-25-2010, 09:29 PM   #7
inferno10's Avatar
Is there no option in the Custom screens to adjust it?
- Jason
10-25-2010, 09:29 PM   #8
dgaies's Avatar
QuoteOriginally posted by HGMonaro Quote
There is a beep as well.
10-25-2010, 09:37 PM   #9
QuoteOriginally posted by dgaies Quote
oops... missed that part, however that introduces another problem... unwanted noise at times...
10-25-2010, 09:41 PM   #10
Wheatfield's Avatar
They put a volume control on it, so you can turn the beep way down. Mine is set so that it is just barely audible when my eye is at the viewfinder.
So far, the camera seems really well thought out. This is the only annoyance I've found so far.
10-25-2010, 09:43 PM   #11
Wheatfield's Avatar
QuoteOriginally posted by inferno10 Quote
- Jason
Not that I've found. They added an option with the K7 as part of (or possibly all of) the first firmware revision.
Hopefully they'll fix this fairly quickly as well.
10-26-2010, 01:23 AM   #12
sterretje's Avatar
My K5 has not arrived yet so I can not test it but can't one not work around it by flipping the AF focusing area to center focus when you want to acces the settings? Only risk is that you might forget to set it back.
10-26-2010, 03:51 AM   #13
not bad for such a great $1600 value, huh?
10-26-2010, 05:02 AM   #14
dadipentak's Avatar
Hat tip to you beta testers--I'm hoping you will have found all the bugs and gotten them resolved before I buy ;~)
10-26-2010, 05:04 AM   #15
RBellavance's Avatar
Oh. I had not thought of that problem when I read the manual. This is very bad. Hopefully they'll adresse this with a firmware update, so we can choose whether a single "Ok" press returns to center AF *or* activates the 4-way pad functions. Personally, I have no use for "return to center AF"...
button, camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, press, settings, switch
Canon S90: Should Pentax Take Note? Miserere Non-Pentax Cameras: Canon, Nikon, etc. 14 03-08-2010 11:53 AM
How to switch to Pentax? keyser Pentax DSLR Discussion 18 12-23-2009 03:49 AM
Pentax Electronic Cable Switch v/s Pentax Infrared Remote Control F brosen Pentax DSLR Discussion 9 10-26-2009 05:08 AM
Note to Pentax Marketing: laissezfaire Pentax News and Rumors 12 10-09-2008 11:58 AM
anyone switch from canon to pentax rwa Pentax DSLR Discussion 12 05-04-2008 07:13 AM
All times are GMT -7. The time now is 07:36 AM. | See also: NikonForums.com, part of our network of photo forums!
