12-05-2010, 10:45 AM   #136
ManuH's Avatar
QuoteOriginally posted by Pentax Shooter Quote
They toled me: "we do not read these forums because most of the time these people do not know what they are doing with the camera"
Which is actually true... but not a good thing to say from a PR point of view
12-05-2010, 12:03 PM   #137
This is a thread i will look into later, own the 360fgz and using it needs some extra attention..
12-05-2010, 12:16 PM   #138
D7000 on day one of its launch had an issue with the video producing bright spots....people ranted about it for a day or so on forums...guess what happened next....Day 5 Nikon released a firmware update to fix it...
As a software developer, I wouldn't install in my camera a firmware that was made public only 5 days after finding out about the problem.
Fortunately, this isn't the case; Nikon is still working on that firmware - they haven't released anything.
12-05-2010, 08:27 PM   #139
vievetrick's Avatar
Ok I am having issues with the K5 and exposure with the flash on and off. I tried a few things and still end up with over exposure on and off. I still love my K5 and hope firmware will fix it. My wife got mine via Amazon and serial number 3839XXX
Exposure(1/60) Aperturef/4.0 Focal Length18 mm ISO Speed1600
Exposure Bias0 EV
FlashOn, Fired
SoftwareK-5 Ver 1.01
Exposure ProgramManual
Metering ModeCenter-weighted average
CameraPentax K-5 Exposure (1/100) Aperture f/2.8
Focal Length 50 mm ISO Speed200 Exposure Bias0 EV
FlashOn, Fired SoftwareK-5 Ver 1.01 Exposure ProgramAperture-priority AE
12-05-2010, 09:40 PM   #140
QuoteOriginally posted by vievetrick Quote
Exposure Bias0 EV
FlashOn, Fired
in order for it to be fixed Pentax has to acknowledge the problem. I discussed this with them about 4 or 5 times via web chat and via phone...every time i talk or chat online with some one they tell me they are not aware and they have not been told of this problem...I told them 4 or 5 times. Also last phone call I made I refered them to pentaxforums.com...they said they do not look at or read forums because "people in these forums do not know what they are doing with the camera"...so good look waiting for a fix. Please call Pentax or chat with them online and alert them to the problem like I did. Maybe they will do something about it. I had the same problem with both cameras i got and returned both of them. I will not buy a Pentax again until i know the issue has been addressed decisively. I am considering a Nikon D7000 now.. it is almost the same camera (although on paper the Pentax K5 is a better camera only if works right). BHphoto sold 120 cameras so far with 10 returns because of this issue. Please call pentax about his issue everyone...if you don't they will never give it any consideration.
12-05-2010, 09:49 PM   #141
actually you are correct, I miss stated the fact...Nikon gladly acknowledge the problem and announced an eminant fix via firmware. Pentax will not even acknowledge the fact that I discussed this issue with them several times regarding the over exposure. They said they have not heard of this issue. I pointed them to look at this forum and see the samples people are posting. I even e mailed them pictures I took based on their request and never heared from them again. I returned both cameras I bought one after the other hoping one will work fine. Both did exactly what you see in these forums. I am sure some lucky K5 owners have cameras that working perfect...but that only means the ones i got are bad apples....which means bad QC from Pentax. Any suggestions?
12-05-2010, 09:51 PM   #142
I had it with DA*60-250
12-05-2010, 09:54 PM   #143
QuoteOriginally posted by jpzk Quote
Good to know.
I wonder how many "to-be-owners" are holding off to buy the K5 because of this.
Might have some luck and actually get a staright answer from Pentax.
I woudn't be not surprised that a Pentax rep would respond that they "were not aware of this problem"
JP
based on my experience you wont get a straight answer. They say they are not aware of any problems. I wished everyone on this forum would call Pentax and complain.
12-05-2010, 11:10 PM   #144
Flash problem was here then gone
As soon as I received my new K-5 a few days ago I immediately tested it for the flash problem being discussed in this thread (AF 540-FGZ). Sure enough, the flash was firing way too brightly. Over exposed shots from too much flash.
I know how to use flash. I have used an external flash every day with a K20D and K-7 in my real estate photography so no reason to think it was user error.
I can't explain it but today the problem is no longer there. I didn't change any camera settings. It's as if the camera needed to be broken in first. I don't have any other explanation.
12-05-2010, 11:17 PM   #145
QuoteOriginally posted by sevenarrow Quote
Sorry for possibly bursting your bubble, but it will come back. The biggest thing with this problem is that it is intermittent. So you can not predict when the camera will screw your picture up.....but if it is really fixed great. What lense are you using?
12-05-2010, 11:18 PM   #146
where did you get your camera by the way?
12-06-2010, 06:13 AM   #147
ivoire's Avatar
Today I received a reply from Metz on an issue I sent them concerning the 48-AF1. Looks like I'll be learning to use manual mode for flash pics.
"Dear Mr. Wolf,
Many thanks for your e-mail as of 02. Dec. 2010.
The mentioned digital-camera Pentax K-5 is checked concerning the flash-mode resp. the remote-mode in our development department at the moment. Thereby we also could realise that the remote-mode doesn’t work correctly. However, the wrong exposures also occur if a Pentax flash unit such as AF-540 FGZ is used as a slave. Therefore we suppose that this malfunction is caused by the camera resp. the built-in flash unit of the camera. Maybe you can check your camera concerning this function at your dealer for example with a Pentax flash unit.
We regret that we are unable to give you a more positive reply at the moment and remain
with best regards
i.A. Roland Laemmermann
Technical Support
_____________________________________________
Metz-Werke GmbH & Co KG
Ohmstraße 55, D-90513 Zirndorf, Germany"
12-06-2010, 08:36 AM   #148
Interesting, I experienced a similar thing if I set the flash compensation to -1ev, I get nice exposures consistently.... I even started a new thread for other people to try out:
https://www.pentaxforums.com/forums/pentax-k-5-forum/124315-flash-overexposur...d-results.html
12-06-2010, 12:47 PM   #149
So far the problem hasn't come back. The K-5 and flash worked flawlessly together today on a real estate photo shoot. This is real world shooting where the use of flash is incredibly important. I thought the flash and K-5 performed better together than with my K-7.
In fact, there were a couple situations where I had to crank UP the FEC.
I'm using both the Sigma 10-20 and Pentax 16-50. Bought the camera from B&H.
12-06-2010, 12:50 PM   #150
QuoteOriginally posted by Eric Seavey Quote
Yes, when I was experimenting with solutions to the problem in my home (before the problem mysteriously disappeared) I had to set the FEC to -2.0. But since last night and during a real estate photo shoot today everything seems normal. No need to reduce FEC.
Time will tell if the problem comes back but so far I'm happy.
camera, dslr, flash, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shots
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 12:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
