07-21-2011, 12:37 AM   #286
Ash
Community Manager
Ash's Avatar
Hmm, interesting filorp. But strange as well.
Would have to see how it goes for me also over the weekend...
07-22-2011, 03:08 PM   #287
Better here!
I have tried PTTL in a couple of modes with a few lenses of various FL's tonight. Usign K5 with AF360, on-body and wireless and so far I was not able to provoke any bad behaviour. Dare I say there seems to be an improvement - was it FW 1.11? Will try some more over the weekend.
07-22-2011, 03:28 PM   #288
Aw, man, I really hate to get my hopes up . . . like I did with 1.03 and 1.10. But I'll try it too.
(Crossing fingers and muttering quietly under my breath.)
07-23-2011, 04:53 AM   #289
Ash
Community Manager
Ash's Avatar
Well, I gave it a go this weekend on a family shoot both bounced and off-camera with wireless triggering. FW 1.11 made absolutely no difference to P-TTL flash exposure. Still had some images OK at FEC 0, and others needing -1.7 or -1.3 for proper exposure. It's now no less reliable, but it's definitely not corrected for me.
Tell you what, though... I've now found that the camera's green AF assist beam now works whilst using an external flash unit. No more slow flash spotbeam! But I didn't take any notice of a menu option to disable that is desired (not that I'd personally want to!)...
07-23-2011, 06:01 AM   #290
filorp's Avatar
QuoteOriginally posted by filorp Quote
holly sh..... !!!!!
Short story. On saturday and sunday, last week i had a wedding (on sunday just location shots). oN thursday i have upgraded to fw1.11. i havent got a chance to check the camera because i had to get to the location of wedding, during the reception when iv started to use the flashgun, i'v noticed something strange - all my photos came out very dark - i had -1.3 flash compensation turned on for all time. i switched to 0 compensation - everything went fine smothly with perfect exposure....
ITS ALIVE - AFTER 8 MONTHS SINCE I BOUGHT THE CAMERA FINALLY EVERYTHINS FINE!!!! It must have been silent upgrade definitely. At Home i checked all other option. When i set flash beam angle to 16mm the overexposure was still there, however when i leave the beam unset at default angle and without difusing panel, everything's fine.... after 8 months!!! FINALLY!!!
amendment: something happend again, flash started to go crazy again, overexposure on white surfaces is pronounced - i swear iv done entire wedding with perfect exposure no compensation.... it depends on something i dont understend.....
07-23-2011, 09:33 AM   #291
It seems to have improved indeed. Now it virtually doesn't matter (in terms of amount of light) whether the flash is on camera or on the P-TTL cable.
07-25-2011, 01:01 PM   #292
Ash
Community Manager
Ash's Avatar
I'm again surprised to find that external flash spotbeam AF assist has returned to haunt me again... I have no explanation as to why the on-camera LED AF assist worked with the flash mounted over the weekend, and now it doesn't but it's confused me. I cannot even find a relationship between settings and the AF assist, but flash exposure seems to still behave the same way (2 stop overcompensation in most bounced situations)...
07-25-2011, 03:25 PM   #293
Maybe a poor example....but it is with 540 flash in wireless with the K5. Flash with the Soffen pointed straight up.
My shot might not do justice...but believe me, Mom's homemade Cherry Pie is to die for! I even offered to give her Otis for another one...but she wisely declined.
My 540 and 360 both work fine on the K5...attached or not attached, straight up or backwards, sideways or upside down.....or any other way you can turn them...I've had no overexposure problems at any time with either of these two flashes on the K5. Whatever the problem is, it does not affect all K5 cameras......or maybe I have the only one where it doesn't?
I will sell it....actually lease it, if you saw my post in another thread...great terms, a real bargain!
Best Regards!
07-25-2011, 10:13 PM   #294
Ash
Community Manager
Ash's Avatar
Now why would you sell (or lease) a perfectly good K-5, Rupert?
I regard the majority of K-5 users have no problems with their external flashes (we just don't hear about them here) and the few who do have issues eager to post in the thread.
I don't have much to complain about myself - apart from the occasional exposure inconsistency in P-TTL, FEC -2.0 seems to do the trick for me - and it has been that way from Day 1 (FW 1.02).
07-26-2011, 01:05 AM   #295
QuoteOriginally posted by Rupert Quote
No you are not unique, I'm also happy with my P-TTL.
10-05-2011, 01:09 AM   #296
Hi all,
I've been really frustrated with the PTTL performance lately. Trying to shoot a party in a night-club. Faces get randomly overexposed! A HUUGE dissapointment! When testing at home, I also get different results, depending on bounce/nobounce and amout of white color in the frame. One thing is for sure: when bouncing, exposure goes up at least 1EV. When there's a lot of white (walls and ceilling), then I get always about 2EV overexposed shots with bounced flash. When not bouncing, then getting even slightly underexposed when no white and normal when with white. This is a bloody riddle, I cannot solve... To me it just seems like PTTL is a bad piece of.... software I'm praying PENTAX to solve this and save me the money of switching to canon!!
ps. firware is 1.11, flash is both: 540 and metz58 af-2, lens is DA16-50 2.8, I use Manual mode on camera (ISO 200, F2.8, 1/100), i tried other modes, don't see much difference
pps. at least metz works more or less fine in A mode. But 540..... it's amazing... in A (a-u-t-o-m-a-t-i-c) you need to set ISO and aperture MANUALLY! Also AF assist doesn't work!! Outrageous.
10-05-2011, 03:58 AM   #297
Lowell Goudge's Avatar
I think the issue in most cases is one of user error, not so much in the actual use of the camera, but in the expectation of the flash.
I have shot 2 weddings as a guest in the past 4 months, one with my K7 one with my K5. In bosth instances, what I found as the issue was that depending upon the metering mode, and auto ISO selection in Av mode, you get wildly varrying results, but all are explainable.
Auto ISO is the worst possible thing you can do with a flash, because the camera will try to achieve exposure without flash first, and as a result, in dark situations you will invariably wind up with ISO Max shots.
For this reason, I always shoot manual mode in flash.
Bounce vs Direct flash also can be a mixed bag, bounce usually is more reliable because it offers global illumination, therefore the flash is much more uniformly spread across both subject and background. Direct flash, if the camera is not looking immediately at the subject, will see mostly background, which is further away. Since flash is a square function with distance, if you do not carefully meter off the subject in the foreground, and let the background fade to black, the subject will be over exposed simply due to the difference in distance from the background
Selection of metering mode can help greatly for this. You may wish to use spot metering and then the camera has a much better chance if the background is further back. FOr a large group, matrix metering may help, but you really need the metering if using matrix mode, to see a large area of bright subkects, A single subject will generally be ignored and allowed to burn out in order to save the highest percentage area of the frame.
Note that the metering is not perfect, and is not automatic. Most importantly it lacks the MINDREAD.EXE function we all assume it has. The flash works reliably within its program parameters, it is us poor humans who don't
10-05-2011, 04:21 AM   #298
setting everything to manual was the first thing I did after seeing the first results with 540, doesn't help
this might be a good point... But why in the situation where I have no object in front at all (just shooting a wall in a dark room), I get EV difference of about 3 when shooting direct and bounced? How can this be explained? If it's a PTTL, it should not matter if you bounce or not. It must always measure the ACTUAL illuminance and act accordingly.
my personal tests didn't show *any* difference between the metering modes... I might need to test more...
I have a feeling then, that canon has been able to discover that one.
10-05-2011, 07:36 AM   #299
filorp's Avatar
andreik - i got the same problem and my conclusion is almost the same... it sound really stupid when one is saing: overexposure depends on haw many white surface is in the frame - i would add: it depends on haw many of ambient light you let to contribute in the exposure the more ambient light the more k5 is prone to overexposure.... but there is a cure: d700 cost almost twice as k5....
10-05-2011, 10:04 AM   #300
I would wait a little... Heard some rumors about d800. Also 5d-mkII is very old.
camera, dslr, flash, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shots
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 04:53 PM. | See also: NikonForums.com, part of our network of photo forums!
