Originally posted by Steelski I think that only 2 cameras before the K-5 went to 51200, The Nikon D3s and Canon 1DMKIV...... and I think only the D3s can say it performs better. At least from what I have seen.
Though this particular thread isn't about that, I would agree with you on that.
And keep in mind that even the mighty D3S won't get by without IQ loss and limitations.
Originally posted by Xatnep_CJ @ JohnBee
Really good PP-job. These shots are so close to each other that one might need a third look to find out the differences.
As far as I have understood your initial posting you will give us a tutorial on how to get such results? What I am also interested in is the question if there is still enough headroom left (PP-wise) to enhance colors and contrast. Or is it pushed to the limits?
With this particular sample, I've found headroom in the following areas;
Highlights
Shadows
Other than channel recovery, color and contrast seem mostly independent type of control points. And they all seem to work within normal parameters.
Originally posted by pspentax and first foto as more DOF than the second one and i don´t look to the exif.
this can be a optic ilusion regarding the more noise reduction aplaied to the second foto.
One more thing John, please post 2 or 3 100%crop from the 2 fotos.
I think you are right about the DOF effect(due to NR).
Also, which areas did you have in mind for crops?
Originally posted by falconeye A has more fine grain detail and more coarse grain contrast (colors look a bit washed out in B).
Excellent points thx!
Quote: I really question the merit of playing ISO games at web resolutions. That's not serious.
I would disagree...
I have printed hundreds of max ISO images from my K20D and plan to do make use of the K-5 in this same way.
I beleive passing-on this knowledge to others will prove to be a great asset to the community both personally and technically.
Especially if we keep in mind that we are not all here as publishers.
Originally posted by NightPorter What's amazing ISO!!!
Photo A ISO 200 (F6.3 1.3'')
Photo B ISO 51200 (F6.3 1/200'')
It's that true??? How can you do that?
It's seem we don't need FF anymore!
Lucky, I will get my K-5 next week.
It is true and I have been hard at work on publishing a step by step tutorial on this very topic.
I'm still not quite sure how I will embed the article in the forum(it's quite long), and so I might have to host it on an independent website instead. However, I'll check in with Adam to see what options we have to work it into the forum first.
