10-27-2010, 06:41 PM   #1
JohnBee's Avatar
K-5, ISO200 vs ISO3200, Sampled from RAW PP/NR: OFF
I was processing some K-5 RAW images(by: dgaies) and decided to give RPP a try.
And I thought the ISO3200 from RAW looked rather good against a nominal equivalent without any NR or PP.
Though a touch of NR could most likely make them quite difficult to distinguish
K-5, ISO200, 13/10s, f6.3, RPP RAW, NR OFF
Full size image here...
K-5, ISO3200, 1/13s, f6.3, RPP RAW, NR OFF
...the end
10-27-2010, 06:46 PM   #2
dgaies's Avatar
My first thought when I just viewed them was "John usually does a better job with the NR".
Then I noticed these were with NR turned off.. not to shabby for 3200 without any NR
10-27-2010, 07:14 PM   #3
jpzk's Avatar
QuoteOriginally posted by JohnBee Quote
And I though the ISO3200 from RAW looked rather good against a nominal equivalent without any NR or PP. Though a touch of NR could most likely make them quite difficult to distinguish
K-5, ISO200, 1/1.3s, f6.3, RPP RAW, NR OFF
...the end
Enough to convince me to keep saving for the K5!
Just can't wait to get this "thing" out there for BIF and other wildlife.
JP
10-27-2010, 07:16 PM   #4
jpzk's Avatar
Has anyone tried the K5 high ISO under difficult lighting conditions, outside, and with moving subjects?
Tough call ... maybe too tough?
Dare! Dare!
JP
10-27-2010, 07:30 PM   #5
JohnBee's Avatar
QuoteOriginally posted by jpzk Quote
Dare! Dare!
JP
You mean, like... when a bird is in the underbrush in low light and you have to really push the system just to identify it, let alone crop to 100% in the process?
Yea... I'd like to see that too!
I can't count the no. of times I ran into this with some amazing smaller birds this summer. The seem to love the early morning and dusk for socializing. Not the friendliest of camera conditions tbh.
I can't wait to test a K-5 in such conditions in spring.
However, I just ordered an adaptall 2 adapter for my 60-300 lens so I can test it against the K-5 without breaking the bank. No clue how it will perform, but I can't wait to see how it works on a D700
10-27-2010, 08:58 PM   #6
jpzk's Avatar
Exactly!
Like last summer trying to get sone pics of very small Kinglets which necessarily inhabits deep coniferous forests, usually right in the darkest part of a tree.
I tried pushing it with the K20D, up to ISO 1600-2000, and let me tell you that it wasn't that great as far as results are concerned.
I did try with the K7 ... no further comment.
What will be the real test is when I get the K5 and go "hunt" for early morning/late afternoon small forest dwelling birds. The combo is likely to be the DA*300/4 with and without the Pentax AF A 1.7X adapter.
At those times, especially during early Spring and late Fall, the light is rather dimmed in the forest to say the least.
If the K5 can handle that, it'll be be a revelation!
Cheers! .... going to bed now here ... early bird gets the worm!
JP
10-28-2010, 03:39 AM   #7
dgaies's Avatar
I think the 3200 w/o NR looks terrific.
How did this compare with the 6400 shot w/o NR?
I forgot there was no 6400 shot
You would think since I took the damn shots I would have remembered that I only took shots every two stops (though in hindsight I wish I had take them at every stop).
10-28-2010, 05:20 AM   #8
Noise reduction definitely is ON in ISO3200 sample
And I am not joking.
There's no colour noise in ISO3200 sample. Only luminance noise. This means, that either camera applied RAW noise reduction or by RAW converter did that— ACR with default settings does some noise colour removal.
10-28-2010, 05:56 AM   #9
dgaies's Avatar
QuoteOriginally posted by Edvinas Quote
There may be some NR done on the RAW file before it gets written to the memory card, but according the OP there was no NR done during the RAW conversion.
For what it's worth, he didn't use ACR for this shot, but rather a raw converter called RPP.
10-28-2010, 06:01 AM   #10
dgaies's Avatar
Also, I don't know if anyone noticed, but I wouldn't read too much into the slightly different blue "blob" just above the beer bottle label. I believe that's just light reflected off the projector screen as it was on during the shots. Had I thought about it, I would have turned it off as the color and amount of light coming off the screen did change depending on what was on TV at that point in time.
10-28-2010, 07:12 AM   #11
JohnBee's Avatar
QuoteOriginally posted by dgaies Quote
Wow I never even noticed!
I was going to process the ISO6400 version today
10-28-2010, 07:16 AM   #12
dgaies's Avatar
Yeah, that's why when you asked for the 25600 shot I had to go back downstairs and take it... which is why the framing isn't exactly the same in the 25600 shot.
Again, in hindsight I should have just taken one at every stop.
It might still be interesting to look at the 12800 shot w/o NR, just for kicks.
10-28-2010, 07:51 AM   #13
Looks very good, except the strange blue artifacts in the highlights. What is that? Look at the highlights in the bars holding the chips. The blown areas are blue.
10-28-2010, 08:05 AM   #14
dgaies's Avatar
QuoteOriginally posted by Gimbal Quote
See post #10.
I think they are reflections from the TV/projection screen I have in my basement. I was watching football when I took the shots, and I have a feeling that is what you are seeing. Had I thought about it, I would have turned the TV off for the shots, but I was just fooling around with a new lens and taking some test shots in low light and didn't think about it at the time.
10-28-2010, 08:16 AM   #15
See post #10.
Ops, missed that post.
But I don't think it is a reflection. It's much too sharp. It might be a bug in the rawconverter though.
camera, dslr, image, iso200, iso3200, k-5, k-5 ii, k-5 iis, k5, nr, pentax k-5, size
K-x and K200D iso200 planedriver Pentax DSLR Discussion 23 01-20-2010 12:22 PM
first k-x ISO3200 photo devorama Pentax DSLR Discussion 6 10-01-2009 02:01 PM
Fuji Superia ISO200 Gooshin Pentax Film SLR Discussion 17 01-25-2009 01:14 PM
The Need for ISO1600 and ISO3200 racinsince55 Pentax DSLR Discussion 29 03-29-2007 10:43 AM
EV range, and ISO200-3200 v.s. 100-1600 kmccanta Pentax DSLR Discussion 6 03-07-2007 05:17 PM
All times are GMT -7. The time now is 06:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
